2000 Viking Saga 1906 Update
Discussion in 'Camper Restoration Projects' started by Squeeker, Aug 22, 2019.
  1. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    DH and I both grew up camping in PUPs as kids. My parents had an early 70’s Bonair that my dad received as “payment” for a plumbing job he did for a friend, and my sister and I practically lived in that thing during the summer as kids. Naturally, I started thinking about getting one now that our DD and DS were at a good age for camping (7 and 4).
    I was pretty sure I knew exactly what to look for in a PUP and easily convinced DH to go look at one I found listed locally. It was all set up when we got there, lights worked, they cranked it up and down for us, floor was solid - SOLD!
    After a couple practice runs in the backyard, we embarked on our maiden voyage 2 weeks ago.
    After camping for 7 nights, we learned what we love and hate about our PUP:
    The good: no leaks, tows nicely
    The bad: need more storage, need an outdoor mat, crank was stiff and a bit jammy, hitch latch was rusty and way too stiff.
    First up was fixing the crank. Found out how to lube the arms by watching some YouTube videos and purchased some silicone spray - check! Smooth as butter now!
    Second, lubing the winch and hitch latch, that was easy. Check!
    Third: more storage. I decided to surf Pinterest for ideas. That lead to pop-up princess...
    Which led to this forum. One week ago I thought I pretty much knew it all. Then I started surfing this forum! Since then I’ve had a tire almost explode (I think I have that sorted), learned about bearings (I have to grease them?! Add that to the list!), and noticed a seam pulled apart that I really didn’t think was of any consequence (buying the stuff to fix that ASAP!!).
    I’ve also decided to have a go at the interior...
    The plan is to paint, lay new flooring, and make new countertops! I’m removing the sink and all plumbing (don’t use it anyway) to gain storage under the dinette, Changing the light fixtures to LED, removing the mostly-peeled-off exterior stripe decals, and building new countertops.
    Stay tuned!
    momofEAP and hq308 like this.
  2. GrueMaster
    GrueMaster Active Member
    172
    55
    May 22, 2013
    Saint Helens, Oregon
    One thing that will help (actually it helps in a lot of areas) would be to change out your land line with a socket on the outside. You can buy this kit, chop your cord where it comes out, seal up the exterior (no more mouse door), and have a more convenient cord to store (actually the same cord, but not shoved into the storage bin from the outside).
    Another simple idea that I employ is to have a bunch of stackable storage totes for cooking. I have one for dry goods (canned foods, sealed spice containers, rice, etc), one for breads and other non-refrigerated goods, and one for all of my plates and flatware that gets used (easier to run it all through the dishwasher when I get home). I keep these just inside the door so they are easily accessible when I roll into the grocery store parking lot, or when I get home, as I only need to crank up the roof 3-4" to get the door open.
    Get some of those large vacuum seal bags to store blankets and pillows in. Keeps the mice out of them, and they can be flattened simply by using your body weight to remove the air (get the ones with the one-way valve on the side).
    (my first comment was attached to one of your photos - oops).
    momofEAP likes this.
  3. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    I LOVE the socket idea!!! Thank you!!!
  4. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Tonight: sanding in prep to prime. Not exciting enough to post pictures of!
    We also purchased new tires and booked our pup in for a bearing job next week (thread about that adventure over in the tire forum).
  5. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Priming! Done! 96725EE0-B222-4319-973A-B4441C1D7A10.jpeg C318F499-C186-4C37-9459-5DCF8784A00D.jpeg AFDC6AA4-BB83-4CA4-8E5C-53AD82A581BC.jpeg
  6. Sjm9911
    4,514
    2,314
    Not exactly sure what goes where, but look into the pop up princess counter shelf mod. It is worth it. Another storage idea, shoe holder attached to the inside of the door ( sunscreen, flash lights, odds and ends) lastly hanging closet shelves. Light weight and fold up. Looking good on the paint job! Good luck.
    Squeeker likes this.
  7. neighbormike
    2,281
    1,667
    Oct 6, 2012
    WI
  8. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Today the PUP is getting new tires and wheel bearings while I’m out of town for work. Can’t wait to get back to painting this weekend!!
  9. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Painting day! Got one coat of grey and 2 coats of blue done. Also got flooring!
    BA14CB0E-77C3-4A13-A01F-A1AE20B45A4F.jpeg 32569337-A4E6-4346-95C1-1C31BED9B328.jpeg 1647D66E-4F7A-4025-B558-A70731AA4EAE.jpeg 77BD1EE9-5AF9-49B6-9ABF-407F70474777.jpeg 91763631-E0E7-48A8-BA68-BA453C24D89F.jpeg
  10. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    I’ve been picking away. Flooring is done; I need to caulk around the edges. Photos of that tomorrow.
    I’ve re-done the bungees on the bunkends with custom brackets (designed by me and made at work) and 1/4” paracord. It looks pretty slick! I’ve also made and replaced the bunk slide/stops.
    57CA0E4D-5398-40F0-B18C-107380F8987C.jpeg 38B70696-5847-412D-9E6D-F73FEB3E02F9.jpeg
  11. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    New lights! LED and dimmable. I got them from amazon.
    Old:
    New:
    CD9D46AE-9162-4F9C-A0B9-92F455A10D6C.jpeg BE9DB7B3-1AF9-4F6D-A09F-83CF6909A9B4.jpeg
  12. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Flooring is in!
    I have learned that I am not very good at caulking...!
    C657D0AE-6B47-4592-A821-F18D6D25B509.jpeg 88992F69-3700-430F-987E-3EB9450E9CCD.jpeg
  13. Sjm9911
    4,514
    2,314
    Look good! No one see the little stuff!
  14. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Countertops cut! This photo is testing the fit. I’m going to trim the one over the fridge (first photo, back right). I made it to the original size, but I’ve decided I don’t like the overhang.
    I rounded the edges with a router, as well.
    4C7804A9-03F0-4523-89C4-DCEF2B74ABAE.jpeg 3262E25E-AD72-4679-B8F8-84B4BC3C666D.jpeg
  15. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Stain! The colour is “flagstone”.
    I’m learning so many new things; this project has been a lot of fun!
  16. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    I’ve been busy varnishing and doing electrical upgrades! New LED porch light, and (thanks to Gruemaster’s suggestion) a new socket for the shore power!
    Tomorrow I hope to finish the varnishing and then seal all exterior seams. I have a half marathon to run first, though, so we will see how I feel!
    82702125-333E-42F3-92C8-D6EC41648351.jpeg 51E24C37-A1D9-442A-926A-D24D52593941.jpeg 2AAC29CB-50E7-47CE-9EF6-3C68450DBE9E.jpeg 3AED9B56-984A-4791-9853-40235AB5EC5F.jpeg 202075C2-60F2-4601-ABF7-F6EBA3029E64.jpeg F944F345-BFEC-47A9-A674-22FAF7783D0A.jpeg 80FE4EA4-8D03-475E-A487-EF506361C359.jpeg
  17. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    Countertops are DONE!!!
    E42BCCD7-FA2B-4BE2-860B-F5D3D1347AE9.jpeg 0DCFB650-75A5-4306-AFF4-640C32486F7B.jpeg EACB9974-2480-467C-9D84-5736D157CF7C.jpeg F35F4483-0D9F-4C07-9274-192BA75E2107.jpeg
    Next up will be fabrics (curtains and seat covers. It’ll be a winter project. Current cushions (shudder):
  18. Squeeker
    Squeeker Member
    51
    26
    Aug 20, 2019
    I’ve ordered curtain and cushion fabric. I’ve also used pro-seal over all exterior seams and added bubble levels to the exterior of the camper. We are about ready to put it away for the winter! The only thing remaining that I want to accomplish is to fabricate a screen to cover the fridge vent to prevent critters from entering. That’s about the only remaining weak spot!
