2001 Coleman Santa Fe Roof cracks
Discussion in 'Roof/Floor Repair & Maintenance' started by Chrissymoh, Jul 2, 2019.
  1. Chrissymoh
    Chrissymoh New Member
    Jun 30, 2019
    Vadnais Heights, MN
    I’ve done some reading on how to patch the hairline and slightly wider cracks in our plastic roof.
    I plan to use the MEK&ABS to patch them but after that the roof needs to be re-painted right?
    Has anyone used any of the Flex seal products (caulk, liquid, spray adhesive, etc...) and what was your experience with that?
  2. bols2Dawall
    bols2Dawall S.W. Ontario
    1,473
    166
    May 19, 2010
    Lasalle Ontario
    As many have said before you " Flex seal might have a place, but not on a pup roof " :)
  3. Sjm9911
    6,422
    3,780
    Just make sure underneath the abs is totally dry. Or it will crack again. If i was going to do it over, i would have removed the abs roof compleatly.
