2004 fleetwood santa fe dining table question
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by rusty3, Aug 5, 2016.
  1. rusty3
    rusty3 New Member
    Jul 22, 2016
    Hi anyone out there have a 04 santa fe .I just picked one up and was wondering about the dining table the legs fold out but the one side hits the plastic wheel well i see that one leg is inset more than the other even if i put that leg against the wheel well the table is quite a bit away from the wall is that the way its meant to be .Thanks
  2. swordfish
    swordfish Well-Known Member
    2,209
    37
    Sep 27, 2010
    Try turning the table around (180 degrees). Just guessing. A picture would help.
  3. Bowman3d
    Bowman3d Well-Known Member
    857
    364
    Apr 13, 2015
    LaLa land (SoCal)
    my Yuma is the same way. I moved the one leg in I think about an inch and it helped but not a lot.
