2004 Viking 2465 ST opinions
Discussion in 'Camper Pre-Purchase Questions' started by Billy29, Feb 22, 2017.
  1. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    A friend at work is selling his 2004 Viking 2465 ST. It's in real nice shape and he took good care of it. The only issue he explained to me is the front storage compartment has a soft spot where some water got in. He believes it happened once because it has not gotten worse since he noticed it and he has not seen evidence of a leak. I'm somewhat handy so replacing some wood isn't a big deal. Also would it be a bad idea to epoxy the soft wood and fiberglass the inside of the storage compartment? What are some things to look out for? Is this a quality trailer?
    This is my first pop up and I want something a little more comfortable than my Eureka Tent. Is $2,000 a fair price ?
    Thanks,
    Billy
  2. JPBar
    JPBar Well-Known Member
    1,873
    582
    Sep 22, 2016
    Texas
    Just look real close at the water damage. If it looks like a easy repair and everything else works like it should and your are comfortable in the purchase than go for it. You did not say what options it may have A/C, toilet, shower, awning, ect... Go here an check the boxes that applies to camper. Good luck!!
    http://www.nadaguides.com/RVs/2004/Viking/M-2465ST/6005976
  3. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    [SNZ]It has everything except air conditioning. I have no reason not to trust him as he's a coworker and I have to see him everyday. I'm not crazy about OSB but it seem like every manufacturer uses it. Book value says around $4,000 but it does have the rot issue. I don't mind repairing it if this is a quality trailer. The canvas is mint and is bright white and the interior is pretty clean. How long of a life can you expect out of a camper like this. He used it every year but took care of it.
  4. dlaudens
    dlaudens Member
    116
    28
    Dec 21, 2015
    Kentucky
    I bought the same camper last year for $3500, but with air conditioning and other extras (BAL leveler, Thetford, mem foam, etc). Also had the front storage wood rot that the previous owner fixed and I've had no issues since.
    I'd say go for it....not every day you find one that is well taken care of. That's what sealed the deal with mine.
    Just make sure you have the TV to haul it....it's pretty heavy, especially once you load it down with gear. The electric brakes are there for a reason!
    Let me know if you have any questions..
  5. JPBar
    1,873
    582
    Sep 22, 2016
    Texas
    For 2K, sounds pretty good. If you take care of it and do regular maintenance it should last for 20 + years, just my opinion though,I would be more worried about lift system working properly than anything else.
  6. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    I have a Toyota FJ Cruiser so it should be fine behind it. I'm going to go look at it in two weeks once the threat of snow is gone. It is wrapped up in a tarp in his back yard right now. He also said he replaced the tires last year.
    How hard is it to add air conditioning? What is a good brand of air conditioner to get?
  7. dlaudens
    dlaudens Member
    116
    28
    Dec 21, 2015
    Kentucky
    Mine has the Dometic which is the factory install and it turns the pup into an ice box if it's on all night.
    I've never added an AC, so I'm not sure how difficult it is. If the search function is working on this site (it hasn't been working recently) you will find all kinds of info on brands and install.
    FWIW - you might want to go without it and see if it's really needed. We went on four camping trips last year (including 15 days in July - east coast) and we only used the AC two times and one of those was just to dehumidify the interior.
    Also consider the types of camp sites you will be using. If you're camping at non-electric sites (i.e. most national parks), you'll need a good sized generator to run it which is another expense.
  8. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    That is another question. Do the National Parks stick you right on top of each other?
  9. jmkay1
    5,637
    2,452
    $2k sounds like a good deal on the camper. In regards to adding an AC after fact at a RV shop, I was quoted $1000. There are some that successfully added the AC on their own to save money. You do have to know if the camper has the AC braces in the roof before you can add one. Others have just bought a portable AC unit to use.
    In regards to national/state parks in my experience there is a little buffer between sites, not as much as you would normally see in the tent section though. Private campground s is where you may be on top of each other. So I try to avoid those places myself.
  10. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    [PUT]How does Viking compare to a Coleman or other brands? Is this a quality camper?
  11. JPBar
    1,873
    582
    Sep 22, 2016
    Texas
  12. jmkay1
    5,637
    2,452
    Pretty much all campers are made about the same now. They all use cheap and lightweight parts. As long as it was well maintained and otherwise in good condition with the floorplan you like, go for it.
  13. Stevo
    Stevo New Member
    Aug 25, 2014
    I got one two years ago for 3300$ It has a strong frame and a lot of features. I had to rebuild my front tool box floor also. Looked like a leaky marker light was the problem. Love the separate shower and toilet. I have completed a lot of up grades. LEDs, lift kit, volt meter, frig fans etc.
    Enjoy!
    Sent from my SM-G930P using Tapatalk
  14. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    What do you guys think of using epoxy to repair the front storage box?
  15. Lincoln52
    Lincoln52 Member
    33
    Nov 14, 2013
    Does it have the Goshen lift system? The winch is on the front.
  16. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    I don't know which system it has yet. I'm going to go look at it in a few weeks. If it has the IDT system is this something that can be fixed?
  17. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    Here are some pictures. As you can see it looks nice for $2000 even with the front compartment floor needing to be fixed. Can any of you tell by the picture what lift system it has?
    https://flic.kr/p/Sh53a8
  18. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    https://flic.kr/p/RbzvJA
  19. Billy29
    Billy29 Member
    55
    Feb 22, 2017
    https://flic.kr/p/RebMk2
  20. 4my2girls
    4my2girls New Member
    Feb 26, 2017
    I would look at the under part of the trailer for floor rot. If you can research on how to fix and patch it and feel comfortable with that. I'd have no idea.. $2000 is a great price if it won't leak. Always look for no rips holes or tears in the canvas and vinyl those are the most costly tof repair the under part of the trailer look up and look for rot in the flooring or a paint where he could have been hiding the rot..
    I have a 1992 I paid 2,800 in CA for it that's a great price for a used trailer in great conditions in Ca!. I have had mine for 3 years, we have gone to the Grand Canyon and take it out just about every month. We have by far gotten our money's worth. Just noticed you posted pictures. I'll take a look.
