2007 Evolution E2 Stock CD Stereo Deck Question
Discussion in 'Campsite Electronics' started by IdCamper, Oct 2, 2012.
  1. IdCamper
    IdCamper New Member
    Aug 15, 2012
    I recently purchased a 2007 Fleetwood E2 and I have a question about the stock CD deck. Unfortunately, I didn't get any manuals with the pop up and I can't find anything online regarding the stock deck.
    On the face of the deck there is a 3.5mm connection that can be used for auxiliary input. I have used this and understand how it works. Under the deck there are red and white (left and right channel) male RCA plugs hanging down that are simply labeled REAR. What are these for? Are they for auxiliary inputs also? If so can I connect a satellite dock to this and still use the 3.5mm auxiliary input on the face of the deck?
    I am afraid to just try it out and see what happens. Any have a manual or know enough about the decks to make an educated guess?
    Now that I have thought about it REAR is probably a sub-woofer output. Sound right?
  2. Raycfe
    16,576
    2,320
    [:D] Welcome from Connecticut, happy and safe camping, enjoy have fun. [CP]
  3. campfreak
    campfreak Active Member
    2,023
    25
    Jan 13, 2011
    I think you are right, they are for a sub woofer. I don't recall seeing them on mine, but that's my guess.
    Welcome from San Diego
  4. IdCamper
    IdCamper New Member
    Aug 15, 2012
    Thanks for the welcome to the forum and also for the guess about it being a sub woofer output.
  5. teejaywhy
    teejaywhy Active Member
    1,411
    Jul 19, 2011
    best to access the back of the unit and see where they are connected. Might be a previous owner's mod.
  6. IdCamper
    IdCamper New Member
    Aug 15, 2012
    Thanks for the advice.
    I ended up taking out the deck. I think the RCA were installed by a previous owner. I eliminated the issue buy just installing a new deck. I can't believe how cheap they are these days.
    Thanks again.
  7. EricElliott 2008 E2
    EricElliott 2008 E2 2008 E2 owner
    19
    Jan 21, 2013
    I have a Fleetwood Evolution 2, 2008. I can't seem to find out how to turn off the radio deck. I hit the power button, but the deck is still lit up....My dilemma is I am charging the camper (shore line power) from the house to charge my batteries. Will this small amount of electricity from the radio deck being on affect the charge both my batteries are getting? I would assume so. but again, it's just a small amount of power to the radio.
    Anyhow...all recommendations are welcome. I'm a newbie.
    Thanks,
    E
  8. bearman512
    bearman512 Well-Known Member
    1,227
    76
    Apr 17, 2010
    Albuquerque NM
    It should not draw enough power to make any difference if it is plugged into shore power. If it has a removable faceplate then just remove it and all the lights will go out.
  9. EricElliott 2008 E2
    19
    Jan 21, 2013
    i'll look again...but i did try to remove it to no luck. I was thinking the same thing though...it's not going to drain the battery much (considering it's just the deck, which is not turned on) while i'm plugged in to my shore power.
    thanks a lot!
  10. EricElliott 2008 E2
    19
    Jan 21, 2013
    Bearman512 - great photos and real nice looking camper! You guys do it right!
  11. bearman512
    1,227
    76
    Apr 17, 2010
    Albuquerque NM
    You have a nice E-2 yourself.
    I honestly think that the E series by Coleman/Fleetwood and the RT series by Starcraft are the best built Extreme Duty pups ever built IMHO.
  12. EricElliott 2008 E2
    19
    Jan 21, 2013
    Thanks! Yeah, I think both are pretty slick! It's a shame that Fleetwood closed their doors.
