2007 Fleetwood Arcadia Roof ceiling issues rebuild
Discussion in 'Camper Restoration Projects' started by Kbooth, Aug 28, 2018.
  1. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    quick walk thru vid
    William Freeman likes this.
  2. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    so, here is where I am at. I used contact after getting everything that was water damaged down, I left the half sheet of non damaged(and really well attached) in place. I decided to lay another layer of Blue dow foam (sorry no pics of that) I attached the foam with contact cement to the old foam. Next I installed the Luan (spray adhesive contact cement again), then I reinstalled the exterior rails (some slight modification was needed since I basically lowered the ceiling by 3/4") the installed the cross members. the cross members really hold this contraption together. I still need to cut the AC hole, and reinstall the AC. After installing the 12v lights, I cant seem to get the electricity to energize. yay another gremlin to kill. next, I have to reinstall the canvas, and paint the exterior of the roof with a sealant to make sure I don't get any water intrusion again.
    tzmartin and William Freeman like this.
  3. William Freeman
    William Freeman Active Member
    177
    98
    May 5, 2018
    Richburg SC
    Wow, wanna come do mine? You're doing a great job - can't wait to see the finished product! What are you going to cover the luan with, or are you going to paint it? I'm really dreading this job over the winter. I kept looking at the ceiling while we were camping this weekend, trying to rationalize that it really wasn't that bad and didn't need to be done this year.
  4. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    The wife had a picture of the foam installed so I thought I would share that. I finally got to the roof coating last night, and found where the water was coming in. the Pictures are of the fiberglass filon roofing. I really don't like this product. It breaks my heart that the product actually cracked and let water in. The Filon has also released from the foam, and has bubbled in some spots. I really don't know what I will do for a long term solution, but and aluminum frame work with solid alum plate sure looks like something I would like. All I have left is to cut the final hole for the AC and reinstall the AC. There is a few electrical gremlins that I need to work out, and a busted water pipe, but I'm getting pretty close to the Make it pretty stage. the wife wants to do a full on re decoration, including painting the cabinets, and new fabric in the cushions. that is going to have to wait till it is not 95 degrees and 90% humidity.
  5. kevinpf
    kevinpf Member
    61
    21
    Jul 5, 2015
    Southern California
    What great work! thanks for the photos and the videos.
    Grizzly Grip that top and the Filon will never leak again. It isn't cheap, I paid about $240 to put 2 coats on my 2008 Niagara, but man does it put a nice flexible shell on you roof.
    Enjoy that trailer!
  6. drocks
    drocks Member
    94
    31
    Jul 15, 2015
    One thing I found when replacing the AC gasket is to also replace the high density foam block toward the back of the AC. This helps to support the rear of the AC and keep it level so that the front of the AC does not raise up and create a gap in the gasket at the front of the AC.
  7. Kitrina
    Kitrina Member
    38
    Mar 31, 2019
    DFW TX Area
    We just bought an '07 Niagara. Is there a specific size gasket or are these all pretty much the same. I've seen 14" gaskets on amazon. Is there a kit that includes the HD foam block and the gasket together? TIA
  8. Kitrina
    Kitrina Member
    38
    Mar 31, 2019
    DFW TX Area
    Thanks for all the pictures and info--we just bought an '07 Niagara and need to do similar repairs on roof and ceiling. For the areas where water leaked, do you remove the foam insulation and replace, or let it dry out and then recover with new luan?
  9. kevinpf
    kevinpf Member
    61
    21
    Jul 5, 2015
    Southern California
    That depends, is your insulation soaked? If so it will likely never completely dry out. When I purchased my 2008 Niagara the roof had leaked and water had run down the seam in the foam ruining the Luan in the middle of the roof. But because I live in SoCal and we had not had that much rain the damage was limited and the insulation never got soaked. the roof leaked around 2015-16 I bought it in March 2016 and resealed the roof immediately but just got around to fixing the ceiling this month, May 2019, and the areas of bad plywood were still damp, not wet but cool to the touch and rotten. The vinyl keeps the moisture trapped in the wood.
    Kitrina likes this.
  10. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    By is the insulation soaked, he means the board insulation that is in the ceiling, not the foam gasket. and to answer you question all the gaskets are 14", and typically they come with the foam rear support for the ac. If you have an "07, I would suggest looking at the front and back of the roof where the fiberglass makes the bend. that is where my water intrusion happened. there were tiny cracks all over the bends.
    I have been working on the camper again, and we are painting the ceiling (finally) and the cabinets. the Wife is recovering the cushions to a more hippy modern fabric print.
    Kitrina likes this.
  11. Kitrina
    Kitrina Member
    38
    Mar 31, 2019
    DFW TX Area
    Yeah, I saw your close-ups of the bend and ours looks very similar with the micro-cracks. We used "Big Stretch" caulking from Lowes and pushed it into all the tiny cracks we could find. We also had 2 spots that appear to be hail dents and caulked those. Unfortunately, the water damage is already in the ceiling--I can see the bubbling and it's soft in a couple areas so that will be our next step.
  12. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    Kitrina, I ended up painting the top with an elastro-metric paint from lowes, and it sealed the cracks, and mate the top white again. I hope to post some pics of the finished paint, and interior renovation this weekend, along with some other modifications that I have found really helpful.
    Kitrina likes this.
  13. drocks
    drocks Member
    94
    31
    Jul 15, 2015
    colemanpopupparts.com has an AC gasket kit that includes the foam block for the rear of the AC.
    Kitrina likes this.
  14. Kitrina
    Kitrina Member
    38
    Mar 31, 2019
    DFW TX Area
    Kbooth, I just tore into my ceiling this afternoon and I know what you mean about there being no adhesion where the moisture is! I peeled back all the plywood I could which was super-easy, but where it is dry, the plywood is very well adhered. My question would be--how do you get all that off? Or can you leave it on, and if you do, how do you evenly cover over it all with the "seams" where the layer of good plywood is still stuck on there? Also...regarding the cross-beams: do you feel it's really important to remove the small amount of water-damaged luan that's under there or would it be okay to leave it? Really don't have the tools, time, or strength to take on removing those ceiling rails...
  15. dmon6388
    dmon6388 New Member
    May 14, 2019
    Nevada
    how did you reattach our pop out tents? my rails are both out and looks like you cant put the tent in before installing the rails due to the screws being behind the tent popout rails?
  16. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    I took out the metal cross brakes down, two bolt on either side. that is also where the luan seams are. makes a great way to hide the repair seams. I wasn't to concerned about getting all the old plywood down, because it will cover, but I wanted to get all of the wet stuff down, because I don't think it would ever dry.
  17. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    I put the rails back in first with screw and not pop rivets, then pushed the splines back into the top rails.
  18. Dave Barno
    Dave Barno New Member
    Apr 4, 2019
    Kbooth,
    Did the elastro-metric paint work well?
    Thanks in advance.
  19. Kbooth
    Kbooth New Member
    21
    May 2, 2018
    Conroe Texas
    it has worked.
  20. ScubaCamper80
    ScubaCamper80 New Member
    Mar 17, 2020
    Oh boy, this brings back some painful memories: I spent HOURS completely ripping out the ceiling in mine last year...it was awful and I never want to do it again!
    As others have mentioned, the AC was leaking and the luan/foam was logged. I did discover portions of the foam that had not become waterlogged: Holy cow - the glue they use at the factory is some unbelievably strong glue (and yes, it must be water-based).
    My biggest problem now: the doggone luan panels & foam boards will not stay adhered to the top aluminum "Skin" of the roof, or to each other!
    There is some really good spray adhesive on the market - I think it's number 77 by 3M but it's got hydrocarbons in it, which will dissolve the foam.
    By the way, no one has mentioned it yet but those Luan panels are very expensive! I was lucky to find them for $70 each.
    As far as keeping the panels elevated and pressed against the outer skin of the top: I used a ratcheting load-brace I got from Lowe's or Home Depot (typically used to keep loads from moving in the back of a pickup truck) - it worked well to keep the ceiling panels in place while the glue dried. Brace
    Word to the wise: when drilling out the rivets to remove the steel corner trim, do so gingerly - there are wires back there for your lights!
    I was too cavalier with my drill and I suspect I ended up drilling into a wire because now that it's all re-assembled, I blow a fuse every time I turn on one of the light switches... And now I'll have to pull it all back down to track down the short (!!).
    Going back to the glue: I used the Luan panels with that white textured vinyl veneer for the ceiling, and replaced the white Styrofoam with the green foam boards from Lowe's (I think it was the 1/2" one? Link to foam panels ).
    What product did y'all use to glue the foam panel to the outer skin, and the Luan board to the foam panel?
