2007 Niagara Rear Panel removal
Discussion in 'Lift Systems' started by Jorja, Oct 5, 2018.
  1. Jorja
    Jorja Active Member
    119
    44
    Oct 6, 2017
    Delaware
    We have a cranking issue we are going to need to fix - popping sound - maybe gear slipping - causing a tight uneven cranking to lowering and lifting the roof.
    I know we can drill out the rivets holding the rear panel on. But there seems to be molding along the edges of the panel - not sure if we can re use these or need to get new - not even sure what it's called.
    Any ideas? (Not our camper pic - but the molding is running up and down between the front panel in this picture connecting it to the side panel.)
  2. mpking
    mpking Well-Known Member
    1,322
    331
    Jun 17, 2014
    Raynham, MA
    Typically if you look at the molding, it's metal with a plastic piece in the center. If you pop the plastic out, it should expose the screws that are holding the trim piece on (and possible the panel itself)
    Jorja likes this.
