2008 Chevy Uplander Towing Suggestions
Discussion in 'Tow Vehicles, Hitch & Towing' started by tjwagers, Nov 24, 2011.
  1. tjwagers
    tjwagers Member
    189
    Sep 12, 2010
    Well...we're the proud owners of a new-to-us 2008 Chevy Uplander LT. (3.9L V6 engine). The van did not come with a towing package but we're (read me) wanting to use it to tow our pup. Any suggestions on hitches and such?
  2. phipps
    phipps Member
    838
    Jan 27, 2007
    Sidney, OH
    First things is how much does your pop up weigh? I'm pretty sure the Uplanders only have around a 2500lb tow rating.
    We have a 2003 Uplander and like it, but I wouldn't pull much of anything with it.
    Check etrailer.com for hitches, wiring, brake controllers, etc.
  3. tjwagers
    tjwagers Member
    189
    Sep 12, 2010
    The pup is under the 2500lb mark. I want to say its maybe 2050lbs.
  4. Unstable_Tripod
    14,279
    42
    May 20, 2008
    Seattle, Washington
    Is that figure empty or fully loaded?
  5. tjwagers
    tjwagers Member
    189
    Sep 12, 2010
    Just checked and its actually 2030 empty. I have maybe 50 pounds (high estimate) of gear that stays inside. It has dual propane tanks on the tongue and a marine battery as well....although if need be the battery can be moved. I never carry water in the storage tank except for short runs of less than 5 miles (I always try to fill up just before getting to campsite).
  6. phipps
    phipps Member
    838
    Jan 27, 2007
    Sidney, OH
    You'll definately want brakes so you'll need a controller.
    How much is the tongue weight? I know ours seems pretty soft in the rear. You may need a WDH or air bags if you can't use a WDH with your pup.
  7. Buffalo
    Buffalo New Member
    46
    Jun 21, 2010
    Add a full size spare tire to the must have check list for the tow vehicle if you don't already have one [2C]
  8. Unstable_Tripod
    14,279
    42
    May 20, 2008
    Seattle, Washington
    A Class II hitch will give you the capacity to tow up to 3,500 pounds of gross trailer weight with a range of 300-350 tongue weight. You'll want a 7-pin wiring system so you can have power to the PUP battery for recharging enroute and to operate a brake controller. (Proportional controllers are best.) You'll also want a transmission cooler.
