2008 Fleetwood Avalon Filon Roof Rebuild
Discussion in 'Roof/Floor Repair & Maintenance' started by s21538, Nov 7, 2015.
  1. William Freeman
    William Freeman Active Member
    177
    97
    May 5, 2018
    Richburg SC
    Sounds like a good plan!
    I know the feeling. It has only been almost a year for me though - does that mean I can put it off for another year, LOL?
  2. kevinpf
    kevinpf Member
    45
    Jul 5, 2015
    Southern California
    Only if the "Boss" allows it[::)]
    William Freeman likes this.
  3. Kathkolck
    Kathkolck New Member
    May 11, 2019
    What adhesive was used for the filon to wood?? I am on my 2nd try :(
  4. kevinpf
    kevinpf Member
    45
    Jul 5, 2015
    Southern California
    Not sure what wood you are attaching to the Filon.
    The Filon is the fiberglass outer shell, then there is the insulating foam panels, and then the Luan wood panel covered by the Vinyl.
    To glue the new Luan to foam I used Loctite "Express Power Grab All Purpose" from Lowes and followed directions, then used an expanding pole and larger piece of thin plywood to hold/put pressure for 1-2 hours while it cured.
  5. Markciu
    Markciu New Member
    Oct 12, 2018
    What adhesive do you use for Filon to foam?
  6. Sarstyle
    Sarstyle New Member
    Aug 4, 2019
    Same boat on my 2006 Williamsburg. I just removed all the bracing and the fiber board ceiling. Now I’m about to pull the roof off to work on it upside down. Looking through threads I haven’t found what adhesive is used to hold the outer shell to the styrofoam layer??
  7. Markciu
    Markciu New Member
    Oct 12, 2018
    I've been reading a lot more, and looks like Gorilla Glue is used pretty frequently for that.
    Sarstyle likes this.
