2015 Aliner Expedition Shower/Bathroom Reassembly
Discussion in 'A-Frame PopUps' started by Thorofin, Jun 1, 2020.
  1. Thorofin
    Thorofin New Member
    26
    May 27, 2020
    Tampa, FL
    Any luck getting those pics? I'm at a bit of a stand still on the project until I can finish plumbing the hot and cold lines.
  2. BostonDad
    BostonDad Member
    61
    49
    May 24, 2020
    Sorry it’s been crazy at work the last week or so. Let me get you those pics now. Hang on.
  3. BostonDad
    BostonDad Member
    61
    49
    May 24, 2020
    7F19D23E-3138-409F-AA39-138AEEFCB06E.jpeg B04A92C5-3922-4D45-9EA7-FDFB902CC0DA.jpeg E63B56E8-D4DA-4F7B-A2CE-3CFD2A36E245.jpeg
    Thorofin likes this.
  4. BostonDad
    BostonDad Member
    61
    49
    May 24, 2020
    AFB64B95-90F5-4FAF-9F16-5976237368BA.jpeg 58D63BCB-CD6A-418F-AC47-FAEAB6417783.jpeg AF1278F4-9522-427C-B51D-9FECB688FFB1.jpeg
  5. BostonDad
    BostonDad Member
    61
    49
    May 24, 2020
    The pics are in order. Should be self explanatory. Good luck!
  6. Thorofin
    Thorofin New Member
    26
    May 27, 2020
    Tampa, FL
    OMG! Those are perfect. Thank you so much!
    BostonDad likes this.
  7. WrkrBee
    5,494
    2,784
    I'd swing that P-trap up closer to the frame. It would still function and a turtle wouldn't take it out, if it ran into it.
  8. Tait
    Tait Member Gold Supporting Member
    52
    36
    May 1, 2020
    I have the same kind of cubby just aft of the shower. I found it helpful to re-route the water lines a little closer to the wall, so they don't go through the middle of the cubby hole!
  9. BostonDad
    BostonDad Member
    61
    49
    May 24, 2020
    That can’t be done easily. Look at the connections and angles and you will understand why. Also, pic is deceiving, there’s probably 9” of ground clearance there which is plenty... unless you’re planning to run into a Sulcata.
  10. Econ
    Econ Well-Known Member
    1,125
    628
    Aug 18, 2019
    Deep South
    Is there water under the dinette bench? Remove all cargo under the dinette bench. Line the floor with paper towels. This will really show the water and position. Drive 350 miles in the rain <<GG>>. What I found was the left front cargo hatch had taken a set with a bow in it. The tightness of the hatch latch caused a bow and the heat caused the set. Sight down the bottom edge and see if it is straight. If bowed enough the gasket doesnt work. Take a piece of hardwood, I think there was some two quarter maple laying around. Bolted it to backof the door just above the lock.
    its now straight. Or you could buy a new door.
    Yes, see below.
    I am currently on the injured /reserve list pending next Mondays Dr appt. If he releases me, I will be back on the portal after early winters tornado season and after monsoon season starts
