2015 Rockwood 1640LTD guidewire missing
Discussion in 'Lift Systems' started by Cozart77, Aug 22, 2019.
  1. Cozart77
    Cozart77 New Member
    Aug 10, 2019
    Afternoon all, we just obtained a popup camper and the guidewire is gone. It there any easy way to replace this? What is the height the roof should raise to?If I knew that I could make my own. We had a pop before this in which the lift cabling got destroyed, and just want to make sure we don't break this one.
  2. kgesiako
    kgesiako Active Member
    122
    95
    Mar 26, 2016
    Chicagoland area
    I would raise roof close to full height then drop down door. Play with roof height till door fits well, then mark the corner posts until you can run a new guide wire. If it is an electric lift, there are adjustments you can make that shut off motor before it goes too high.
  3. MileHigh
    MileHigh Active Member
    458
    52
    Jul 18, 2012
    Denver
