ChocoChock01
On the road aagaain See Rallies below;
- Mar 7, 2012
- 4,029
Maybe is good!Haybale said:Maybe in!
Means your back in saddle again![emoji1]
Bret:Rc_maniac said:you could just do it on here and repost an update whenever it changes.
Same here! haven't seen anyone in quite a while. Looking forward to it. We will for sure be making it down to see the North Rim on Saturday because we've never seen it before. We had planned a trip up there last year but an unexpected financial situation killed several of our trips last fall.
where was the original image located? on your private server or a public server?94-D2 said:Brian, when I was doing the Shasta summer rally last year I would post a jpeg img from a screen shot with updated info. So basically, you are replacing the list using the img link. It displayes whatever you put in that photo and doesn't require a new post. That way you can eliminate list confusion as we see only what you put on your image.
my moderation rights were taken away...94-D2 said:Another thought is if you have moderator rights on the portal you should be able to edit posts. That would allow you to post updated lists and delete old ones. Then you simply add a post advising the subscribers of the new list. The same could be done for other rallies. WM would post new lists and pm a moderator to delete old lists with the specific post number to delete.
Just another though......
Cannot make it yourself?ChocoChock01 said:I need to cancel my reservations for Site #31, does someone want it before I release it?
Oh, why? How sad! We'll miss you!Rc_maniac said:Cancelled.
and you'll most likely never see me again because i'm selling my TT.
shuang2 said:Oh, why? How sad! We'll miss you!
