3.73 version 4. 10 rear
Discussion in 'Tow Vehicles, Hitch & Towing' started by vagov, Aug 25, 2016.
  1. skeetercampsintexas
    1,759
    22
    Jun 26, 2012
    Wylie, Texas
    I have the second that the 2 valve 5.4 was a much better motor than the 3 valve, minus that whole blowing spark plugs out the heads thing [LOL] a little trick though to the stuck spark plugs in the 3 valve, and yall will all think I'm nuts, take them OUT with an impact. It'll rattle them right out of there. Obviously don't put them in with one.
    On the gear ratio thing I run 410s front and rear in my pickup and enjoy them thoroughly. Although my highway speed rims are higher I can tend to manage with the use of my chip. The right gears when towing can make all the difference in the world on how much the truck struggles to get up to speed.
  2. turborich
    turborich Active Member
    1,908
    Jun 22, 2010
    Las Vegas, NV.
    Don't think you're nuts at all, make sure the engine is still warm as well. [2C]
  3. Rusty2192
    Rusty2192 Well-Known Member
    903
    351
    Jul 30, 2014
    Kentucky
    I don't think the OP was suggesting changing the gears, rather choosing between trucks with different ratios from the factory. In that case, the rear end gearing can make a slight difference in towing capacity. Although it looks like on most '06 F-150s it is the same between the 3.73 and 4.10.
  4. rustybronco
    rustybronco Member
    179
    Jul 7, 2016
    Ain't that the truth.
    I've often wondered how much better those -3V engines would be if the owners would have used a Motorcraft filter (or other premium filter) and Mobil 1 out of the gate? Not all of those issue are attributable to the design. Most owners have no clue what it takes to properly maintain a vehicle. "What do you mean I need to change my air filter?" :rolleyes:
  5. tenttrailer
    3,190
    311
    Jul 18, 2013
    Thornville, OH
    I would go with 3:73 assuming the truck has 300 hp or greater. But I would drive the TV the rest of the year when not towing and would hate the MPG with the 4:11. Now it it was only going to be used as a TV I would go 4:11
  6. vagov
    vagov Well-Known Member
    4,206
    380
    Aug 13, 2012
    Pittsburgh, Pa
    Went to look at the 06 with the 4.10. But declined the body was rough in spots, not looking for perfect. Undercarriage was bad
  7. sgip2000
    sgip2000 Member
    536
    Jun 16, 2010
    Hillsboro, OR
    I wouldn't be too concerned about a 4800 ft mountain.
  8. vagov
    4,206
    380
    Aug 13, 2012
    Pittsburgh, Pa
    Thanks for the insight now I have at least some more insight and knowledge on what to look for it look out for as the hunt continues
  9. jumpoff
    jumpoff I'm in a camping state of mind
    1,553
    188
    Nov 3, 2015
    North East Florida
    a 4800 ft mountain at a steep enough grade is going to be a challenge for any vehicle pulling a heavy enough trailer....
  10. jmcclung11
    jmcclung11 Active Member
    1,163
    Aug 10, 2008
    Fishersville, VA
    Its not the size of the mountain...Its the % grade. There are some 8% and 10% grades for 2-3 miles in WV.
    Sent from my Samsung Galaxy SIII.
  11. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Exactly jmcclung11
  12. tenttrailer
    3,190
    311
    Jul 18, 2013
    Thornville, OH
    there are some 12% grades getting on to the BRP that will take you down to 1st gear if towing.
  13. jmcclung11
    1,163
    Aug 10, 2008
    Fishersville, VA
    Yep!
  14. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    What is the BRP?
    Sent from my KYOCERA-E6560 using Tapatalk
  15. Beecoach
    Beecoach Member
    299
    Jun 13, 2014
    Ah never mind figured it out
  16. sgip2000
    sgip2000 Member
    536
    Jun 16, 2010
    Hillsboro, OR
    Happens all the time in the Rockies. Just gotta downshift and go slow.
  17. f5moab
    1,423
    468
    May 7, 2013
    Somewhere in Idaho
    Best answer yet....
    I have a 5.3L with six speed trans and 3.42 gears (towing package) and pulling my 3200 lb Popup with a tongue weight of 510 lbs has never given me a problem going up and down the 10% or higher grades (like Teton Pass at 8500 ft); nor does it cause a problem using the engine/trans to brake coming down. Same for I-70s, 6&7 percent grades to Eisenhower pass.
    Best is to match the engine/trans and drive gears for best of all driving modes.
  18. Jughed
    Jughed Member
    250
    Aug 14, 2015
    I have a 4.10 and love it. My truck is 6200# to begin with, so the gearing helps a bunch.
    As for mountains - we've towed across the Rockies, Utah, AZ - up to 11,000 ft... the worst hill we climbed was the road up to Cheaha state park in Alabama. Only 2000'+/- at the top, but 16% grades in some places. Not a steady climb - short steep downhills followed by short steep climbs. You instantly go from taking care of your brakes to pulling hard up the incline. 4000+ rpm in 2nd gear...
    We went down the backside of Cheaha without the camper, probably with 1,500 of gear and people in the truck and my brakes were smoking at the bottom - and we were locked into low gear. Total elevation drop was about 1000'. This didn't happen coming down Pikes Peak with the same load - total elevation drop was 6,500'+/-.
    East Coast = short but steep climbs.
  19. Haybale
    2,484
    312
    Aug 22, 2013
    San Diego via MN
    Did you ride your brakes down the entire grade in low gear?
  20. ScoobyDoo
    ScoobyDoo New Member
    367
    Aug 23, 2016
    Yes, a 8% for a couple of miles will be tough, but if it starts at 4000 ft it will be much tougher then 4000 at top.
