3 way fridge propane useage
Discussion in 'Refrigerators and Coolers' started by hotrodcamper, Mar 17, 2018.
  1. hotrodcamper
    hotrodcamper Member
    972
    Nov 3, 2012
    How much propane does a 3way fridge use? Thinking of using it for 3 weeks straight. Will a 20# LP tank be sufficient?
  2. BikeNFish
    BikeNFish Well-Known Member
    3,493
    2,355
    Apr 24, 2017
    Maplewood, MN
    Your propane usage to run the fridge will be minimal. The whole cooling system basically runs from just the "pilot light". You should be good for three week on a full tank. With that being said, the propane will not last three weeks if you are also using the stove, water heater and furnace. If this is the case, you will need a refill or bring an extra tank.
    Fbird and kitphantom like this.
  3. NMroamer
    NMroamer Well-Known Member
    721
    462
    Apr 21, 2016
    Albuquerque NM
    Never hurts to have a spare, especially when the tank you are using goes empty at 3am.
    Ask me how I know.
    jnc and Fless like this.
  4. generok
    generok Well-Known Member
    2,845
    1,177
    Feb 7, 2013
    Anchorage, AK
    If you only ran the fridge on LP and nothing else, 3 weeks would be a cinch. It sips LP.
  5. theseus
    theseus Centerville, OH
    2,896
    441
    Feb 6, 2007
    Centerville, OH
    I've gone whole summers on a single 20lb tank just using it for the fridge. As generok says, it sips LP.
    Fbird likes this.
  6. MNTCamper
    MNTCamper Well-Known Member
    1,198
    397
    Jun 14, 2014
    MN
    Won't be a problem, we use ours on a three week trip as well as camping for the rest of the summer. We don't use the furnace or WH, but we use the stove everyday to cook on.
  7. speckhunter80
    4,782
    64
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    you could probably get over a month of refrig use on a 20lb tank
  8. nineoaks2004
    8,214
    3,677
    Dukes, Fl
    I always carry a spare, I use it for the BBQ, and if needed for the RV. It is better to have a spare
    than to have to spend the time find a place to fill the LP tank.
  9. davido
    davido Well-Known Member
    955
    250
    Jul 17, 2014
    I've estimated about 21 days on propane, but that means not consuming propane for anything else.
    If you run the furnace, stove, and water heater, the fridge won't even factor into your equation of consumption:
    A 20# propane tank has about 430kBTUs in it.
    My furnace consumes 19kBTUs per full hour of run-time.
    No idea what my stove, BBQ, and water heater consume. Surely less than 19kBTUs.
    The fridge consumes 550 BTUs (not kilo-BTUs, just BTUs) per hour. So the fuel consumed by running the furnace for one hour would keep my fridge going for almost a day and a half.
    I really like having dual propane tanks. I never go through an entire tank in one camping trip. But that's not the point. The point is that when I run out in one tank, the automatic regulator flips over to the second tank without missing a beat. The fridge keeps on going. Meanwhile I can disconnect the empty tank, and take it to be refilled. Mount it back on the trailer again, where it sits until the alternate tank is depleted. As long as one tank is full, and one is somewhere between nearly empty and totally full, I am comfortable setting out on a trip.
    theseus likes this.
  10. hotrodcamper
    hotrodcamper Member
    972
    Nov 3, 2012
    I’ve got 2 tanks with the auto changeover valve. Thinking I should be good from what everyone has said.
