3 way low boy question
Discussion in 'Plumbing Systems (Blue, Grey, & Black)' started by Rhconcepts, Jul 30, 2016.
  1. Rhconcepts
    Rhconcepts Active Member
    615
    100
    Oct 1, 2015
    Blaine MN
    I just installed a 12v pump and a 3 way low boy. To get the low boy to trigger the pump I need to pull up on the handle pretty hard. If i let off it shuts off right away. Is that how they work? I was thinking I would keep running.
  2. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    Does anyone use a 3way low boy?
    I plugged the 3rd intake because water was coming out of it and now it's really hard to pull the handle up. Should I hook the 3rd intake up with my water tank? I could put a T in the line so they both are hooked up to the pump. Right now I have one small one going to the pump and the large one going to city water and the other small one is capped off.
