$300 1992 Palomino Mustang Renovation
Discussion in 'Camper Restoration Projects' started by Rideswithchrist, Jun 23, 2017.
  1. Rideswithchrist
    Rideswithchrist Member
    139
    24
    Jan 18, 2016
    Buda, TX
    https://www.lowes.com/pd/Style-Sele...rk-Brown-Peel-and-Stick-Vinyl-Plank/999957675
    We took a tip from here and ran them horizontal so it gave the appearance of a larger space. It was also faster since we started in the storage area and needed to cover the seam we made repairing the floor.
    We cut them with heavy duty steel scissors (we call them murder scissors because of the many accidents we have had with them)
  2. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    I cut some to stick in the door where it is peeled, but they did not stick. I guess we need glue and clamps for that.
  3. Bowman3d
    Bowman3d Well-Known Member
    778
    261
    Apr 13, 2015
    LaLa land (SoCal)
    I'm worried about that and am wondering how hard it will be to peel up the old floor covering first.
  4. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    We just put it down over the old flooring.
    Orchid likes this.
  5. DJS12354
    DJS12354 Well-Known Member
    1,550
    479
    Sep 21, 2017
    Thinking of doing the vinyl floor in our pup when Spring rolls around. I'll wipe the floor down with some alcohol before putting the peel and stick down. My thought is that it will remove any soap residue that may prevent sticking properly. Anyone have thoughts on this?
  6. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    that is a great idea. I know some people wiped with TSP but we just vacuumed it and called it good. The only places is did not stick well was over the gap where we filled with Great Stuff, but we weighed it down and it is sticking now.
  7. Bowman3d
    778
    261
    Apr 13, 2015
    LaLa land (SoCal)
    Use isopropyl alcohol. I found while building arrows that other alcohol leaves a residue that made the fletching glue not stick well.
  8. DJS12354
    1,550
    479
    Sep 21, 2017
    Should have said that I would use Isopropyl. It does a pretty good job without being insanely toxic.
  9. Orchid
    Orchid Sharp Shootin' Grandma
    5,269
    1,951
    May 8, 2011
    Florida by way of WV and MD
    @Rideswithchrist, what an amazing job your family has done with this camper! I really admire your willingness to put so much hard work into making a nice camper for your family. Wishing you all the best and many happy memories in it!
  10. Mamie
    Mamie Active Member
    839
    111
    Sep 11, 2017
    LA - Lower Alabama
    I saw something online that you use with vinyl with adhesive backing as a primer. It wasn't too expensive either.
  11. Bowman3d
    778
    261
    Apr 13, 2015
    LaLa land (SoCal)
    Henry's self stick primer
    Mamie likes this.
  12. Rideswithchrist
    139
    24
    Jan 18, 2016
    Buda, TX
    Thanks guys!
    We still have a long way to go. The other bunk needs repair and we ran out of time and money.
    I think we may be one of those that move to a hybrid next
