3rd wire in battery box?
Discussion in 'Wiring' started by LaneG, May 20, 2020.
  1. LaneG
    LaneG Member
    45
    28
    May 20, 2020
    50 Miles north of Seattle
    Hi, I'm a tent trailer newbie. Read my intro to get all the details.
    I replaced a broken up battery box on my 2005 Fleetwood Victory. It had the two black and white heavier battery wires and then a third lighter gage wire that wasn't hooked up to anything. I tried to search for the answer already and didn't find anything definitive.
    Anyone know what this is for? Anyone have a wiring diagram?
  2. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    Does your pup have electric brakes? Maybe the light gauge wire powers the break away function of the brakes?
  3. Snow
    11,469
    2,082
    Trace it, only way to know for sure. There really isn't specific wiring diagrams for trailers, like there is for cars.
    Wrenchgear likes this.
  4. tzmartin
    tzmartin Not here for a long time but here for a good time! Diamond Supporting Member
    1,338
    669
    Sep 9, 2015
    Clayton, Georgia
    What color? Does it look like it came original with the camper? Could be a remnant of a 12v mod someone added on.
  5. GreyFox
    GreyFox Well-Known Member
    2,447
    1,277
    Oct 10, 2018
    S Ontario
  6. Raycfe
    17,458
    3,020
    Most likely an add on ......... power jack, a light for hitching up, breakaway switch, a power socket that could be anywhere on the camper.
    As Snow replied ............ Trace it for sure ........ label it so you know next time.
    I have never seen a camper wiring Schematic that had a good diagram of the battery connections. Usually they are just interior stuff. And a wiring diagram won't show a wire that someone added.
  7. rabird
    7,656
    768
    N. TX
    the wire could be for the breakaway switch that activates the brakes if the trailer becomes disconnected. Likely connects to batt +.
    the cable on one end attaches to you vehicle while towing and should pull out the plunger to activate the brakes if the trailer becomes disconnected.
    trace the wire as see where it goes.
    good breakaway primer
    http://popupbackpacker.com/how-to-test-a-trailer-breakaway-switch/
  8. LaneG
    LaneG Member
    45
    28
    May 20, 2020
    By posting my question here. I was hoping for a easy answer. That everyone had one of these third wires and it is universally for such and such. Silly me, huh?
    Thanks to you all for your help. To answer a few of your points...
    1. Yes it does have electric brakes.
    2. It is yellow and black (maybe brown) striped wire. See picture.
    3. It does look like it is original with trailer as it goes into wiring harness like the two bigger ones.
    4. Thanks to GreyFox for the link. There is a lot of good info there. I did find a picture in there for my unit. And it does list a yellow/black wire near the sink and kill switch and pump. But I can't make out exactly what it is pointing to.
    Looks like I'm just going to have to trace it like suggested. But I'll have a look first near the kill and pump switch.
    So you guys have helped and I appreciate it.
    Happy Trails
    Lane
  9. Raycfe
    17,458
    3,020
    It maybe a feed to the convertor. I would check the wires in the back of the convertor. Just a hunch.
  10. rabird
    7,656
    768
    N. TX
    if its not a breakaway switch wire then you need to make sure you have one!
  11. LaneG
    LaneG Member
    45
    28
    May 20, 2020
    Good idea.
  12. LaneG
    LaneG Member
    45
    28
    May 20, 2020
    Yes, when I get my brake controller wired up. I'll make sure the brakes work.
  13. McSkippy
    McSkippy Active Member
    139
    120
    Sep 10, 2019
    Colorado
    You don't need a brake controller to test the breakaway switch.
  14. Jimbow
    Jimbow Well-Known Member
    1,789
    363
    Nov 30, 2012
    If your pup comes loose from the TW your controller will also be disconnected. The breakaway switch will lock the trailer brakes and hopefully keep the pup and everything around it safe.
