3way lowboy hookup ?
Discussion in 'Plumbing Systems (Blue, Grey, & Black)' started by Rhconcepts, Sep 19, 2016.
  1. Rhconcepts
    Rhconcepts Active Member
    615
    100
    Oct 1, 2015
    Blaine MN
    I installed a 3way because I bought a electric pump. The city water and electric pump side work great. The manual pump side started to leak so I capped it off. If I want to hook that up then I need to add a T before the water goes into the electric pump, right?
  2. Dubbya
    6,130
    71
    Aug 2, 2011
    Steinbach, MB
    Yep, that's how I did mine. I added a "T" right at the tank fitting.
  3. Rhconcepts
    615
    100
    Oct 1, 2015
    Blaine MN
    Thanks, wasn't sure if the pump would still work correctly.
