4 nights below freezing on one tank!
Discussion in 'Boondocking' started by MaeKay, Oct 16, 2019.
  1. MaeKay
    MaeKay Well-Known Member
    699
    260
    Oct 18, 2017
    Utah
    We’ve made it 4 nights already on just one standard propane tank. Each night the weather has been at or just below freezing and we’ve stayed so comfy in our little travel trailer with the furnace. (It’s mid 60’s during the day so we’re only using it at night).
    This summer we learned how long we could boondock in regards to water and electricity. But now we’re getting an idea of the furnace propane usage. (Obviously actual temperatures will affect it and will be different each trip.)
    Tonight will be night 5. It’s only supposed to get down to 40 so I was willing to risk it to see how far we can stretch our propane, especially since there isn’t a propane refill station nearby us currently. Love learning what our little trailer can do. And I love that we are able to be much more flexible in when we can go camping.
    Arlyn Aronson and unclemark like this.
  2. bobinfleet
    bobinfleet Well-Known Member
    1,023
    428
    Sep 2, 2011
    Hampshire UK
    Great to hear people are still out and about
    unclemark and MaeKay like this.
  3. JimmyM
    JimmyM Well-Known Member
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    We're headed out this weekend too in Rhode Island.
    Take a cup of hot water and pour it down the side of the tank to see how full it is. It would be interesting to know how much you have left.
    MaeKay likes this.
  4. MaeKay
    699
    260
    Oct 18, 2017
    Utah
    We ended up going 6 nights and when we filled the tank back up when we got home we were shocked to find we’d only used 3 gallons! I thought we might be super low because when I tapped on it that first couple nights it all sounded the same. I thought that meant it was empty. Nope, it was just still mostly full! So far the battery is our biggest limiting factor and that’s still pretty awesome.
  5. jmkay1
    5,673
    2,480
    Sadly heating my popup I only got 4 nights. However one night was real windy the I had so many cold drafts get inside,the furnace had to run so much more often to keep to temp.
  6. Spridle
    Spridle Well-Known Member
    1,180
    379
    Jun 6, 2011
    We can get three to four days in the pup as long as we get it filled full, as opposed to just a 80% tank swap. Keep it at about 50 at night and then bump up to a nice 65 in the morning until everyone warms up.
  7. Camper054
    Camper054 Active Member
    280
    134
    Jul 23, 2019
    Indiana
    @JimmyM, for my learning, what do you mean by this? How can I tell how much I used/left by pouring hot water down the side of the propane tank? Many thanks!
  8. BillyMc
    BillyMc Well-Known Member
    1,538
    860
    Mar 25, 2018
    The liquid propane sits at the bottom of the tank. When you pour hot water down the side of the tank it warms the metal. The metal in contact with the liquid will cool more quickly than the metal above the liquid line. You can determine how much LP is in the tank by where the temperature changes.
    unclemark likes this.
  9. Camper054
    280
    134
    Jul 23, 2019
    Indiana
    @JimmyM, thanks so much - got it. Have a wonderful day.
  10. JimmyM
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    Actually... Thanks, BillyMc
  11. unclemark
    unclemark Overland Park, KS
    382
    45
    May 15, 2014
    Overland Park, KS
    Thanks for mentioning this. It will be very useful.
  12. Econ
    Econ Well-Known Member
    693
    334
    Aug 18, 2019
    Deep South
    And if you are home weigh the 20 pound tank and subtract 16.6 pounds, take the remainder and divide by 4.2 (propane pounds per gallon) and you have gallons left.
    Camper054 likes this.
  13. Camper054
    280
    134
    Jul 23, 2019
    Indiana
    Thanks @BillyMc , thanks @Econ :). Much appreciate you alls helps...have a wonderful winter!
  14. gladecreekwy
    959
    1,244
    Sep 25, 2016
    Jackson Hole
    I believe the water trick works better if there is propane flowing.
  15. gladecreekwy
    959
    1,244
    Sep 25, 2016
    Jackson Hole
    I’m always amazed by how long the propane lasts. We don’t run the furnace continually all night preferring a double wide warm sleeping bag. Turn it on to warm up the camper in the morning. Do some cooking on the stove. We easily get 10 nights out of a tank.
    Arlyn Aronson likes this.
  16. gladecreekwy
    959
    1,244
    Sep 25, 2016
    Jackson Hole
    D23341A9-E603-4970-8313-6598DA16DD1E.png Been thinking about this. Anyone use one?
  17. BillyMc
    1,538
    860
    Mar 25, 2018
    It will work but you have to be able to lift the tank. Requires unmounting and a real PITA if you trying to do it under a bunk end.
  18. JimmyM
    2,893
    901
    Jun 5, 2014
    Franklin, MA
    The hot water trick works quite well. Even if no propane is flowing.
  19. Arlyn Aronson
    Arlyn Aronson Well-Known Member
    1,564
    1,065
    Jun 11, 2014
    Houghton, MI
    I just unhook the tank strap and shake it a bit with its hose still attached.. Seems its easy to tell if its on the low side. If its low, then bring an extra tank along. I'd not purchase that tank wiegth gauge. I like simple. My head works best that way. [:O)]
