801 duck, unknown vintage
Discussion in 'Camper Manufacturers & Manuals' started by Amarada, May 21, 2020.
  1. Amarada
    Amarada New Member
    28
    May 16, 2020
    West Tennessee
    I am starting to get deeper into fixing up this NTM 801 duck. I do not have a title, I do not find a vin (only a scrap of label near the door and possibly some unreadable numbers on the tongue?) I think it is 1990's. I have three questions:
    1. how can I date it? The table is pedestal style, and there are two pinstripes (one green and one white) and a decal of "Dutchmen" with a goofy duck in the "D".
    2. I have downloaded a 1994 manual I found online and it was TOTALLY not what I'm looking for. I really would love a manual, though it may not exist.
    3. Does a wiring diagram exist? or is there a post about what it "should" look like? three outlets do not work, but the dome light and one outlet do work. I have not found a battery yet, but there does seem to be a heater and a converter. My hubby is an engineering tech and could rework it all, but we need to know what our end goal is!! BTW, I have been in the portal for only a week and ya'll are ONE AMAZING HIVEMIND!
  2. GreyFox
    GreyFox Well-Known Member
    2,447
    1,277
    Oct 10, 2018
    S Ontario
    If by "outlets" you're referring to duplex 120 vac receptacles then the ones that don't work are likely all on one circuit and probably protected by GFCI (Ground Fault Circuit Interrupter) that has either tripped or is faulty and needs to be replaced.
  3. Amarada
    Amarada New Member
    28
    May 16, 2020
    West Tennessee
    Yes, I did see GFCI on one of them (a little sticker), but they don't have the reset button like I have in my house. My DH keeps asking me if anyone has a wiring diagram, so he can start tracing/testing the wiring. I am interested in working receptacles, he is interested in bigger stuff, lol!
  4. GreyFox
    2,447
    1,277
    Oct 10, 2018
    S Ontario
    Pretty difficult to come up with a relevant wiring diagram when you aren't at all sure exactly what Dutchmen camper you have. :oops: According to this NADA listing Coachmen didn't start manufacturing "camping trailers" until 1994, including the M-801-Duck. If it helps, here's the Dutchmen manual download webpage.
    Amarada likes this.
  5. Amarada
    Amarada New Member
    28
    May 16, 2020
    West Tennessee
    I know!!!! Would pictures help if someone "knows their ducks"?
  6. Amarada
    Amarada New Member
    28
    May 16, 2020
    West Tennessee
  7. WrkrBee
    WrkrBee Un-Supported Member Silver Supporting Member
    6,012
    3,126
    The sticker just means that receptacle is protected by a GFCI. There's another receptacle in there with the two buttons, test and reset. Someone could have just put a sticker on it, also, and it means nothing. Or, there was a GFCI there and someone removed it. Camper troubleshooting can be like a can of whoop ass when you follow previous owners mods.
    Amarada likes this.
  8. GalsofEscape
    GalsofEscape Well-Known Member
    1,030
    483
    Nov 26, 2013
    Maryland
    there may be two electrical systems, one is DC (runs off of battery) and the other is AC (often called shore power or 110v). Typically, stuff like the lights, water pump, and furnace use the DC power. Outlets and air conditioners use AC current and will only run if the camper is plugged in (outlet at the house or at the campground). There can be a converter that converts AC power to DC to run the DC items in the absence of a battery or when the camper is plugged into shore power.
    Kyle R Thorson likes this.
  9. Fless
    Fless Active Member
    971
    212
    Aug 14, 2012
    Colorado
    Is there a weight sticker on the driver's side (left) panel, near the front of the camper, that shows the weight values? If so, that may have a clue as to what model number it is and the date of mfr. My former Coleman's looked like this:
  10. WrkrBee
    6,012
    3,126
    There can be a converter that converts AC power to DC to run the DC items in the absence of a battery ONLY when the camper is plugged into shore power.
    Amarada likes this.
  11. GalsofEscape
    1,030
    483
    Nov 26, 2013
    Maryland
    correct - a slight mistype on my part. thanks.
  12. Rusty2192
    Rusty2192 Well-Known Member
    1,136
    550
    Jul 30, 2014
    Kentucky
    On my ‘95 802D, the gfi outlet is right next to the converter, then that feeds the other normal outlet at the other end of the pup. Those are on the 15A circuit breaker. There’s a 20A outlet for the A/C on it’s own circuit and breaker. When you’re plugged in to shore power make sure the circuit breakers aren’t tripped. If you have the same old Magnetek converter as me, just push in on both of the round buttons to reset the breakers. If none of your outlets are gfi, someone has probably replaced it and you’ll want to get a gfi back in there considering pups aren’t exactly the most watertight things in the world. The converter is probably in one of the dinette benches. Here’s the manual for the Magnetek 6400 Series in case that’s what you have.
    http://parallaxpower.com/wp-content/uploads/sites/8194/2018/09/6400-Owner-Manual.pdf
    If you had a battery, it would be on the tongue. My Duck didn’t have any factory wiring specific for a battery, but does have a black 10G wire to the tongue that you just tap into to hook up a battery.
    Mine has the VIN stamped in the tongue, but I have no idea if that’s from the factory or if a previous owner had done it themselves.
    6F7E9303-D68C-4C8D-918E-6823F259B76E.jpeg A475B24E-727D-48BB-A684-B0C8624B7509.jpeg
  13. Amarada
    Amarada New Member
    28
    May 16, 2020
    West Tennessee
    I found the reset, it was on one of the outlets under the dinette. Now all the outlets work.
  14. Amarada
    Amarada New Member
    28
    May 16, 2020
    West Tennessee
    So, I was mistaken. There is no heater, no battery, but there is a propane refrigerator. Slowly figuring out this little camper. At least it seems pretty simple!
