'85 Jayco 1008 SG Original Tire/Wheel Size?
Discussion in 'Tires / Brakes / Bearings / Axles' started by Jayco85, Apr 15, 2007.
  1. Jayco85
    Jayco85 New Member
    Mar 22, 2007
    Anybody out there have any idea what the original tire/wheel size was for a 1985 Jayco 1008 SG? I suspect the previous owner(s) increased the size because both the 5.30x12 and 4.80x12 tires that came on the PUP (???) prevent the rear bunk from sliding out if either is mounted onto the rear spare bracket.
    Scott
    1992 Ford Conversion Van
    1985 Jayco 1008 SC
    1988 Rockwood 34' Motorhome
  2. Jayco85
    Jayco85 New Member
    Mar 22, 2007
    I need to clarify that one of the previous owners painted over the little trailer spec plaque that is attached the frame. In addition to not knowing the original tire size, I don't know what the weight is either.
    Scott
    1985 Jayco 1008 SG
    1988 Rockwood Class A Motorhome
  3. cyclesteve
    cyclesteve Member
    55
    Jan 27, 2007
    Scott
    I have a 1985 Jayco 1008 SG. The original tire size:
    size Load range Maxumum load Inflation PSI cold
    5.30 x 12 C 1045 80
    Weight:
    empty weight GVWR
    1270 with standard equipment 2205
    I also have the original owners manual. As soon as I have time I will scan and download to the site. Hope this helps.
    Steve
