'94 Coleman Destiny Royale Bed Slides
Discussion in 'Slide-Outs / Bunkends' started by bstat, Feb 15, 2020.
  1. bstat
    bstat Member
    33
    17
    Sep 24, 2019
    I live where you vacation, NC
    I'm in need of replacement nylon/plastic parts for my '94 Royale. Anybody know where I can get them and does anyone have a diagram or something so I know what parts I'm missing too?
    Thanks!
  2. Sjm9911
    5,965
    3,419
    bstat likes this.
  3. bstat
    bstat Member
    33
    17
    Sep 24, 2019
  4. Sjm9911
    5,965
    3,419
    Unfortunately, thats the extent of my knowledge. Good luck!
  5. bstat
    bstat Member
    33
    17
    Sep 24, 2019
    I found part numbers!!! Now to hunt them down.
    I need part numbers 4747B3691 and 4747B4061.
  6. bondo54
    bondo54 Well-Known Member
    1,522
    46
    Aug 15, 2010
    I have seen where the piece still in the end was drilled and taped 1/4x20. Then took a bolt that was long enough to have a sholder. Bolt was screwed in till it came to the sholder and the hex head of the bolt was cut off.
  7. bondo54
    1,522
    46
    Aug 15, 2010
    bstat likes this.
  8. bstat
    bstat Member
    33
    17
    Sep 24, 2019
  9. bondo54
    1,522
    46
    Aug 15, 2010
    Ok your orginal post did not say what parts you were looking for.
  10. bstat
    bstat Member
    33
    17
    Sep 24, 2019
  11. JJJONZ
    JJJONZ New Member
    Dec 2, 2019
    I just replaced mine. I got them from the same place and they were 18 inch and $29.95 each. You have to drill out the old rivets to remove the old slides. You then have to put new rivets. The hardest part was finding the rivets. I had to take my new slide to a place that has rivets so they can fit them.They are aluminum 1/4 inch,I don't remember how long. Real easy once you find the rivets.
  12. bstat
    bstat Member
    33
    17
    Sep 24, 2019
    Mine are actually different and held in with screws. the biggest reason I'm hunting for better pictures is because the first few pictures don't look like what i need but the last picture kinda looks right. Want to make sure its at least close before I buy enough to replace all of the bunk slides.
