95 STARCRAFT STARFLYER WONT GO ALL THE WAY UP
Discussion in 'Lift Systems' started by robynbanks, Sep 23, 2013.
  1. robynbanks
    robynbanks New Member
    22
    Dec 10, 2012
    WHEN TAKING I DOWN CPL WEEKS AGO IT FELL ABOUT 6 INCHES THEM STOPPED. WE CRANKED IT THE REST OF THE WAY AND LOCKED UP . WHEN HOME OPENED UP TO CLEAN OUT AND ONLY GOES UP TO THE SPOT IT FELL TO THEN WE HAVE TO PROP IT UP THE REST OF THE WAY. HELP WHAT DO I DO?
  2. backwoodzbum
    backwoodzbum New Member
    477
    Jun 15, 2007
    Crank it up till it stops....and you need to inspect the posts cables and the cables under neath and see if any of them show slack. You may also want to look at the manual and check the raised stop nut is set properly. Go slow and methodically until you figure it out.
    Here is your lift system manual.
    http://www.popupportal.com/index.php?action=media;sa=item;in=3148
