96 rockwood signature series lift problems
Discussion in 'Lift Systems' started by mirandab1, May 29, 2010.
  1. mirandab1
    mirandab1 New Member
    25
    May 29, 2010
    also the the gear above the clutch is a little wobbly too do you think i need to replace them bearings to
  2. Xolthrax
    Xolthrax Franconia, Pa.
    4,649
    Mar 17, 2007
    Franconia, Pa. Butter capital of the East
    It will work perfectly. My newer one has the same "double sprocket". My old one was a single. There was really no difference in how they operate.
  3. mirandab1
    25
    May 29, 2010
    question there looks like a pin that holds the rachet pawl i can see the pin on one end but looks to be broke on the other under the cabinet can i just use like a a pin with a carta pin or something and how do the pawl release when you let the roof down?
  4. mirandab1
    25
    May 29, 2010
  5. mirandab1
    25
    May 29, 2010
    well i got it fixed thanks to all for the support
  6. Xolthrax
    4,649
    Mar 17, 2007
    That's GREAT news. Sorry, I didn't see your last 2 posts in time to respond.
    I don't know if you can see it in this picture,
    but I replaced the bolt holding my pawl in place with a cotter pin. I had that stroke of brilliance after about the 3rd time I needed to remove the pawl to work on the system. They didn't make it as easy as they could have to unscew that thing!
    Good luck. Now that you've completed the repair, I'm sure you understand the lift system much, much better than before. Go tell the "technician" that misdiagnosed your problem as a shear pin that perhaps perhaps they should think twice about guessing about this lift system. You could easily have spent ALOT of money to have them not fix your problem.
  7. crusher
    crusher New Member
    197
    May 30, 2010
    Glad to hear you got it repaired sorry I have been extremely busy and havent been on here in a few days.
  8. kgallagher
    kgallagher New Member
    Jul 14, 2010
    Re: 94 rockwood signature series lift problems
    How hard is it to time the chain drive from side to side. Still not sure how to replace the spring. i have the camper up all the way and braced and the cabinets out.
    PLLEASE HELP IF YOU CAN [?:~{]
    KRIS
    PS just found the instructions [:O] [RTM]
    still need help
  9. plumes
    plumes New Member
    Jul 7, 2010
    OK....I did this repair also, except......
    I am having a heck of a time gettining the first c-clip, the one nearest the bearing, back into to place. i can not squeeze the assmeby together tight enough to get in the correct lot on the sprocket. Thoughts?
  10. Xolthrax
    4,649
    Mar 17, 2007
    I remember it being a pain in the patookas to get back on, but I was able to do so with a thin needlenose pliers. What I don't remember is having to squeeze the assembly to be able to fit the pin on.
  11. firebobofire
    firebobofire New Member
    Oct 12, 2021
    I know this thread is way old. But I’m having the exact same problem. Why can I not see the images that the members posted? Am I doing something incorrect? Thank you
  12. WrkrBee
    WrkrBee Un-Supported Member
    6,527
    3,444
    Nope, you're fine. Software and forum platform changes have rendered image links useless.
  13. firebobofire
    Oct 12, 2021
    Do you recommend just starting a new thread asking for diagrams for what I need?
  14. WrkrBee
    6,527
    3,444
    Back reading the thread, looks like contacting Canvas Replacements may help. They may send you instructions and diagrams needed to troubleshoot. Starting another thread is an option, too.
  15. firebobofire
    Oct 12, 2021
    I will try there. Thank you
  16. WrkrBee
    6,527
    3,444
    Welcome to the Portal.
