98 Casa grande no interior lights/water pump & outside light do work
Discussion in 'Wiring' started by Bhut2180, Nov 5, 2019.
  1. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    So let me start by saying I hate electrical work, it seems so simple and it isn't. So I'm heading to Stone Mountain this Friday and I'd really like my interior lights to turn on by battery. Battery has been fully charged. Grounds all appear good, all fuses appear good. The outside light by the step turns on via battery, the water pump for the sink turns on via battery. I've replaced the Gally switch to allow interior lights and water pump to work, it's obviously allowing power to the water pump and with the switch off, no water pump, so check that's working. But no lights up top. I also replaced the breaker on the positive black battery wire. I've checked the wires running to the roof, they appear plugged in correctly, I'll potentially try pulling those apart next. I'm at a loss
  2. tombiasi
    6,152
    1,685
    Did you try changing the bulbs?
    1380ken likes this.
  3. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    Sorry forgot to add they are new led bulbs that did work when plugged in initially two trips ago
  4. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    I did put some different bulbs in, still no go
    bheff likes this.
  5. NMroamer
    NMroamer Well-Known Member
    785
    496
    Apr 21, 2016
    Albuquerque NM
    Use a test light or meter to check for voltage at the lights.
  6. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    This switch appears to connect to the wires going to the roof lights, no apparent place to plug it in
  7. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    Waiting for my neighbor with a meter to help me with that
  8. bheff
    bheff Well-Known Member
    1,504
    923
    Feb 24, 2011
    NW Arkansas
    Remember that LED lights are polarity sensitive. It is possible to install some bulbs in backwards.
  9. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    I'd read that, so I switched them back and forth to no avail
  10. 1380ken
    1380ken Well-Known Member
    2,502
    892
    Nov 7, 2013
    Mass
    The lights worked two trips ago? Try to figure what changed since then.
  11. Snow
    11,104
    1,766
    Sounds to me like the safety switch is toast...
  12. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    I replaced the safety switch, and confirmed it works because my water pump will turn on if the switch is on and won't if it's off
  13. Bhut2180
    Bhut2180 Member
    65
    22
    Apr 30, 2019
    I stored it for two months is the only thing. Installed new lights at the end of a trip, checked to make sure they worked, then stored for next trip, opened it up and they didn't work
  14. Econ
    Econ Well-Known Member
    997
    532
    Aug 18, 2019
    Deep South
    Wire break??
  15. TRR
    TRR Active Member
    460
    233
    Nov 3, 2014
    Alabama USA
    Check the wires that run through the canvas up to the roof. There's often a plug connection up near the roof so it can be disconnected to remove the canvas. That connector may be unplugged, loose, or damaged. All of the ceiling lights get their power through that line.
  16. Snow
    11,104
    1,766
    Never seen a water pump wired to the safety switch before.. [Edit] Never seen an outside light wired to the safety switch either ..
    Find the wire run in the canvas up to the lights and check the connector..
  17. GreyFox
    GreyFox Well-Known Member
    2,447
    1,270
    Oct 10, 2018
    S Ontario
    Stop guessing and start measuring with a voltmeter.
    Econ likes this.
  18. tombiasi
    6,152
    1,685
    X2
  19. NavarWynn
    NavarWynn Member
    78
    38
    Jul 20, 2019
    SAV, GA
    X3 - at the very minimum a test light, but a cheap DMM can be had for a few dollars at Harbor Freight or under $10 on Amazon. Frankly, it's a necessary component for practically ANY kind of electrical TSing.
    Based on your description of the work you did immediately prior, my first guess would be in the wiring to the ceiling lights. If you pulled on a wire connection during the installation of the LEDs , and it loosened up (say because it's 20yrs old?) or partially separated, then you dropped the roof, I could easily see that putting tension on the wire and breaking a connection... and such would easily cause your problem.
    Obv. that's just a guess.
  20. tzmartin
    tzmartin Not here for a long time but here for a good time! Diamond Supporting Member
    1,258
    600
    Sep 9, 2015
    Clayton, Georgia
    . I have the same model. I think you took a picture of the factory heater connector. X2 on checking the wire at the fixture. Try checking the outside pin connection near the post above the refrigerator.
