98 sea pine mattress topper suggestion?
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by Bestshooter, Apr 18, 2020.
  1. Bestshooter
    Bestshooter Member
    74
    Mar 4, 2020
    Ga
    Hey guys ,
    Wanted to see what everyone was doing for either great mattress toppers or a new memory foam bed . I think the front is a king size so not sure what size to order either . What have you used and how comfy is it ?
  2. fourhallatts
    fourhallatts Well-Known Member
    1,104
    399
    Jul 18, 2015
    North Syracuse, New York
    We had to replace our mattresses because mice had gotten to them before we purchased it. I probably would have replaced them anyway since as I get older I find it harder and harder to not think about who used it last. We purchased memory foam and a zippered mattress cover for it. It is a little softer than I would really like but we sleep pretty well on it.
  3. Raycfe
    17,005
    2,575
    Three inches, four better of memory foam. The 2 we use are over 5 years old and used in 2 different campers. Amazon has a lot of different ones.
  4. GreyFox
    GreyFox Well-Known Member
    2,338
    1,185
    Oct 10, 2018
    S Ontario
    A standard home king size mattress is 80" long x 76" wide, the "king" bed in your Sea Pine is 77" long x 70" wide. Unless you can find someone who manufactures the custom size you need you'd be better off using a memory foam topper you can trim to size. However the roof likely won't fully close with the toppers sitting on the existing mattress and would have to be removed & stored separately for travel. We used a Novaform gel memory foam topper from Costco on the rock hard mattress in our Freedom Express travel trailer and slept like lambs. [A]
  5. eoleson1
    eoleson1 Well-Known Member
    2,813
    1,119
    Jul 5, 2011
    Macomb County Michigan
    We had a three inch topper in our Starflyer and we were still able to close the roof. I had to push on the roof a bit to compress the topper, but it worked fine for many years that way. We bought a standard king topper and cut it down to size using an electric knife.
  6. ezakoske
    ezakoske Active Member
    587
    99
    Nov 30, 2014
    Escondido, CA
    We went the inexpensive route, and bought a foam egg-crate topper from Joann fabrics, and then trimmed it to fit om top of the current mattress.
    Would love to upgrade the mattresses, but custom sizes are $$...
  7. Sneezer
    2,084
    929
    I found some toppers on clearance at Walmart a couple years ago. Mine are not memory foam - just regular foam. I used an electric kitchen knife to trim them to size. Can't remember the height, but I think they were 2-3". I sleep better in my pup than any bed now. I also put those interlocking foam anti fatigue mats under the mattress. On mine I found the mattress to be overly soft, so my fat butt would bottom out. This combination solved all my sleeping issues, but I cannot keep the bed made when I drop the roof as I am now at the max room available. Bedding gets folded up and stored under the dinette for travel. I use old mattress bags with some luggage straps to help keep them compressed. Works a dream.
  8. Bestshooter
    Bestshooter Member
    74
    Mar 4, 2020
    Ga
    Thanks I ended up going with a 3” gel memory foam topper from kohl’s . Gonna try that out
