99 coleman Seapine weak brakes
Discussion in 'Tires / Brakes / Bearings / Axles' started by Td, Aug 27, 2019.
  1. Td
    Td New Member
    Feb 15, 2013
    Took drums off and all seems ok. Magnet and drum have little wear. Found ground by bumper and put a new end on. Tested voltage at 7pin. Tried brakes by pulling break away cable. Adjusted star wheel. Still brakes won't even hold me on a slight hill. Checked ground on brake controller. All looks good. What next. Since I had drums off I put new seals and bearings also. I'm at a loss now.
  2. joet
    4,984
    1,065
    Check voltage at the connections at the wheel. Weak magnets? and don't expect the brakes to lock the wheels
    Raycfe likes this.
  3. Grandpa Don
    Grandpa Don Well-Known Member
    589
    315
    Sep 5, 2018
    What type of controller do you have? The control voltage on mine is adjustable from 14 to o volts. Around 4 Volts is fine for me. Also, are you brakes new?
