99 Starcraft Meteor Wiring ?
Discussion in 'Wiring' started by gbberton, Mar 6, 2011.
  1. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    I'm installing a new 7 blade pigtail to my pup's stock wiring harness. The Pup end has 2 black wires, one is heavier then the other. the new pigtail only has one black. my question is what which black wire do I use? And what do I do with the other one? Any help would be appreciated.
  2. dackley
    dackley 1999 Jayco Heritage Laurel with popout
    261
    Dec 24, 2010
    go to starcraft manual section on this web site for wiring diagram.
  3. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    I have looked at, but I'm not that good at reading schematics, just thought someone might know why there are 2 black wires.I was just hoping someone on here might have a 99 Starcraft PUP and be able to help.
  4. starcrafty
    starcrafty Guest
    If you have the crazy 8pin rectangular Starcraft wiring harness still in your '99, I think you can wire the two blacks together to go to your 7-blade round. They had a seperate larger black to charge PU battery, and the smaller for the 12V fridge and othe things. The wire colors on the 8pin don't necessarily match up to the new round plug, either, but I'm sure you have noticed that.
  5. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    All of the wire colors were the same on the new pigtail that I bought from e-trailer and the factory Pup end, just the one extra black wire. So I shoud just wire the 2 black ones together then?
  6. Raycfe
    15,390
    1,569
    yes
  7. starcrafty
    starcrafty Guest
    What Raycfe said. Yes. Did everything else turn out correct when you finished and plug into the TV? Just curious.
  8. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    The camper is parked at my sons house, so I won't be able to check it till the weekend. So I will let you know then.
  9. gbberton
    gbberton New Member
    21
    Feb 6, 2011
    I hooked up to my TV today and all lights and turn signals worked just fine.won't know about the rest till Saturday.
  10. starcrafty
    starcrafty Guest
    Good deal!
  11. spotter35
    spotter35 New Member
    Jun 26, 2016
    We just bought a 99 starcraft meteor and we can't figure out the wiring harness. It's a 7 pin rectangular and no one we've spoken with has heard of it. The guy we bought it off of bought it used and then never used it. We're trying to connect it to a 4 pin but can't find an adapter. Can you help?
