99 Starcraft Spacemaster - Shelby Winch questions
Discussion in 'Lift Systems' started by jmatasov, May 21, 2017.
  1. jmatasov
    jmatasov "Never tell me the odds." -Han Solo
    125
    21
    Aug 19, 2016
    Western NY
    So I am rebuilding a Spacemaster and have it down to the bare frame. Got a good look at the winch and it looks a little rusty and rough. It is working fine, but I am wondering if there is any maintenance or care I can do to it to make it last a lot longer? Do any parts need lube or anything?[​IMG]
    I ordered new lift cables since the old ones have rusted and seized up turnbuckles, and have my fingers crossed I will be able to get the threaded hex screws out of the drum so I can replace the cables.
  2. jmatasov
    125
    21
    Aug 19, 2016
    Western NY
    UPDATE: A bit of dry lube and some new lifter cables and it's all set! Turns smoothly, and once I added lithium grease to all of the pulleys, everything is butter-smooth...[​IMG]
  3. jzachary
    jzachary New Member
    Jun 1, 2017
    Celeste , Texas
    Got a question for you. Is there a way you could give me a measurement of your roof height to the top edge of camper wall. Im pulling 4 different measurements and my 2000 starcraft classic top is definitely leaning to the road side
  4. jmatasov
    125
    21
    Aug 19, 2016
    Western NY
    @jzachary - Well, I can when I get to that point. But right now my camper looks like this, so those measurements are a bit hard to come by... [:D]
    Although I just replaced all of my lift cables, so my first raising will be...interesting to say the least...
  5. jzachary
    jzachary New Member
    Jun 1, 2017
    Celeste , Texas
    @jmatasov i see that lol. Thanks ill see if i cant find some measurements online somewhere
  6. jmatasov
    125
    21
    Aug 19, 2016
    Western NY
    When I raise mine up I am going to adjust the turnbuckles underneath until the door top swings down and fits the bottom half comfortably, then I will adjust the rest to match that relative height.
    Scrounging online i found a winch/lifter repair manual for a 1984-86 Starcraft camper. The setup looks exactly like my '99, so I am using that as a rough guide. I will edit this with a link to it when I get it it posted (or find the original link)
    RichardV likes this.
  7. jzachary
    jzachary New Member
    Jun 1, 2017
    Celeste , Texas
    jmatasov likes this.
  8. jmatasov
    125
    21
    Aug 19, 2016
    Western NY
    @jzachary - Here's where I found the winch/lifter info on older Starcraft Campers... 84-86 Starcraft Camper Cable Service and Installation
    The only real differences I found was that I think my camper has more lifter segments, and the 'stop nuts' shown for adjusting the total overall raising and lowering of the camper in the pdf have been replaced with collars with set screws on my camper.
  9. PDXPhil
    PDXPhil New Member
    Sep 1, 2017
    Thanks for the pictures. My pop up, 1984 has the same winch. One cable to the winch is broken. How do the cables attach to the winch?
    Thanks
  10. BillyMc
    BillyMc Well-Known Member
    1,519
    827
    Mar 25, 2018
    The poster hasn't been on the portal since January 2018. You may find what you are looking for here.
  11. davekro
    davekro Active Member
    601
    191
    Aug 30, 2019
    SF Bay Area, CA
    Billy,
    Thanks for the PDF of the winch system. What the OP shows seems to be what is exactly on my '99 Stardust. I've read some place that some have 1-2 zirk grease fittings, But from my initial peak under I do not hink I have those. My winch looks exactly like the OP's pics. Is that the same winch you have (like OP's pics)?
    Have you heard there is any more lubricating than spraying silicone spray? I have done that to the (4) corner pulleys under the floor, and a bit from the sides of the winch itself, but I could probably do a better job there. I notice that my roof seems to have maybe on or two corners that are a bit lower than the other two (1" maybe?). Would that cause any, even small amount of binding to make the raising harder than need be? I have no idea what the normal amount of muscle it should take to crank the top of my 10 footer's roof.
    Not sure how to have described the amount of muscle it 'should take'. At the risk of sounding sexist, should a child or small lady be able to rotate the crank without straining?
  12. BillyMc
    1,519
    827
    Mar 25, 2018
    My winch looks like the one in the pictures and PDF. The handle has a small sort of oval opening that slides over the shaft. We have a 12' box with a Coleman AC one top. My wife "can" crank it, but finds it a bit more strenuous than she likes. A teen through older adult in decent shape should be able to raise it without great effort. Mine is pretty much even when raised, the back side may be a smidgen lower as the AC condensation drips on that side. I take that as a plus because the kids aren't tracking through the wet dirt into the camper. If there are grease fitting I haven't found them.
    I really haven't done much with the lift system. Used spray lube on all moving parts. I did loosen one of the cable the first trip out because one corner was higher than the others. Turns out the cable had some how gotten crossed with another cable.
  13. davekro
    601
    191
    Aug 30, 2019
    SF Bay Area, CA
    Oh, thanks for that ‘crossed cable’ mention. I’ll see if I can check for that before attempting to adjust. I did no the read thru the PDF, but I I imagine it describes how to adjust the the heights. Is all the adjustment done via the turnbuckles I see under the box on the cable(s)? Doesn’t seem like a lot of adjustment distance, but maybe it is only +/- an inch on each cable.
  14. davekro
    601
    191
    Aug 30, 2019
    SF Bay Area, CA
    Don't miss this Shelby 5438 Lift System Info:
    Even though, as BillyMc mentioned, the OP has not been on this site since 1-1-18, his initial pictures and info are valuable for all of us with the Shelby 5438 lift system! Do look at the link to the PDF of the '1985 & newer Starcraft Lift System' (initially posted #10 by BillyMc) https://rvworkshop.com/sc_images/Starcraft_1985___Newer.pdf
    Also see this thread by SpacepiG "1990-2000 Starcraft liftsystem Shelby 5438" with clear pictures and a good description of how the brake system works. https://www.popupportal.com/threads/1990-2000-starcraft-liftsystem-shelby-5438.119981/
  15. davekro
    601
    191
    Aug 30, 2019
    SF Bay Area, CA
    After being pointed to how to access the two pulleys in each upright support channel by Billy, here is a description of what I learned.
    1) Raise the top about half-way or ≈ 2' (or any height you happen to already have boards sized at)
    2) Place ≈ 2' boards at each of the four corners (I used two, to do one side at a time.)
    3) Lower the crank 2-3 turns until there is a decent amount of slack in the cables inside the channels.
    4) Slide the center SS channel down a few inches and the upper pulley will be free of the cable to be spun as you spray Silicone lube on it.
    5) Slide the center SS channel up a few inches to free the lower pulley,
    6) Use long angled needle nose pliers, insert below lower pulley and pull up on the cable to free up the pulley to spin while lubing.
    7) Raise the top back up to be able to remove the 'support boards' [ Done! ]
    Only 2-3 of my eight support channel pulleys were not spinning freely, but it felt good to 'know' that they all are now!
    When I first got the pup a few months ago, I had sprayed some of the under frame pulleys, but I had not 'detentioned them and spun the pulleys as I lubed them- Very important! This week I un-cranked the crank to detention them all and lubed and spun them. Plus, some pulleys had debris from bugs and weeds etc. that I cleaned away.
    Slide channel up:down.jpg
  16. davekro
    601
    191
    Aug 30, 2019
    SF Bay Area, CA
    I had read that a perk with Coleman pups was that water /rain was OK to be on the support channels because it drained thru to the ground, not to the pup's floor like all other pups. So as I was doing my under frame pulley lubing, I checked out 'if' in fact it was true that water down the channels on my '99 Starcraft went to the floor, Yes. Now I know why I need to repair the Velcro so the vinyl 'channel covers' can actually be held in place. ;o) Fortunately, I only had minimal (visible) rot at the front left corner!
