A/C Advice
Discussion in 'General Camping Discussion Forum' started by stud muffin, Jun 7, 2017.
  1. stud muffin
    stud muffin New Member
    18
    19
    Jun 7, 2017
    Hello all,
    I am a first time popup camper owner. I want to install an A/C on the roof. I already have a vent there. I have searched amazon and google trying to find an A/C to no avail. I checked with the authorized dealer for my brand (Jayco) in the area and they wanted $1,000 to purchase and install the A/C. I can do it myself if I can just find an A/C. Any advice on where to go to buy one? Any brands you recommend? Does anyone know where to buy second hand A/Cs? Like a junk yard, etc...? Thanks for any insight you may provide.
  2. giadiep
    giadiep Active Member
    389
    164
    Sep 5, 2015
    Syracuse, NY
    Craigslist - rv section. I've seen used units there on occasion.
  3. silvermickey2002
    4,627
    437
    Sep 11, 2008
    Morris County, NJ
    Careful buying a used one. Just make sure it is a working unit! Otherwise you will be spending time troubleshooting a problem. I know for our pup the dealer had to use a Fleetwood/Coleman A/C install kit. Check to see if you need an A/C install kit for your pup.
    We installed a new unit in May of 2014. It's a Coleman Mach 8 low profile unit. 13,500 BTU. Including installation by our dealer it came to $1,200. The unit weighs 90 lbs. It's a great unit, we are happy with it.
    stud muffin likes this.
  4. stud muffin
    18
    19
    Jun 7, 2017
    The only units I've seen in craigslist are portable units.
  5. stud muffin
    18
    19
    Jun 7, 2017
    Did they install some type of brace in the interior of your roof? My local dealer said that if I were to do it that I would need to add a brace.
  6. giadiep
    389
    164
    Sep 5, 2015
    Syracuse, NY
    I'm in central New York near Syracuse. There are some units that come up on Craigslist for around 2-300. I don't know about how well they work as I've never inquired on any of them. I have a rooftop unit on my HTT. Guess it depends on the area.
  7. silvermickey2002
    4,627
    437
    Sep 11, 2008
    Morris County, NJ
    @stud muffin,
    Our pup has two interior roof braces it came with from the factory. I will assume if yours doesn't have braces then you will need them. I would check with Jayco what is required for an A/C install.
    By the way, I was going to ask where you got the Stud Muffin name, but I don't think I wanna know!!
  8. JPBar
    JPBar Well-Known Member
    1,866
    574
    Sep 22, 2016
    Texas
  9. stud muffin
    18
    19
    Jun 7, 2017
  10. JPBar
    1,866
    574
    Sep 22, 2016
    Texas
    This video shows a camper like yours with an A/C. Hope this helps.
  11. kreeves
    kreeves She and her two dogs
    153
    26
    Dec 4, 2016
    West Virginia
    Make sure you have a brace. The previous owner put one on my camper, but now I have to take it all the way off and brace the roof and put it back on. It has a sag in the center that would just let water pool there if I don't fix it.
    bob barnes and stud muffin like this.
  12. Spaceace5150
    Spaceace5150 Member
    137
    24
    Oct 1, 2014
    Another first time pop up owner here..
    Has anyone tried using a portable A/C unit for their pop up? I have one without air but am trying to avoid installing a roof unit (due to the cost).
    Interested to hear your thoughts!
  13. silvermickey2002
    4,627
    437
    Sep 11, 2008
    Morris County, NJ
    If you do a search you will find many folks did what your looking to do.
    Just found this post:
    http://www.popupportal.com/threads/portable-air-conditioner.106580/#post-1077109
    Spaceace5150 likes this.
  14. Spaceace5150
    Spaceace5150 Member
    137
    24
    Oct 1, 2014
  15. bob barnes
    bob barnes Well-Known Member
    1,343
    196
    Mar 26, 2017
    I have often wondered watching those pu s going down the highway with those a/c units on top just doesn't look good to me!!
  16. silvermickey2002
    4,627
    437
    Sep 11, 2008
    Morris County, NJ
    We have a Coleman Mach 8 Low Profile unit on ours.
    bob barnes likes this.
  17. bob barnes
    1,343
    196
    Mar 26, 2017
    Is the top reinforced or something?
  18. silvermickey2002
    4,627
    437
    Sep 11, 2008
    Morris County, NJ
    There are two braces inside the pup roof. They are specifically placed on each side of where the A/C unit is. The pup came with the braces from the factory.
  19. bob barnes
    1,343
    196
    Mar 26, 2017
    so do the braces drop down when putting the top down?
  20. JPBar
    1,866
    574
    Sep 22, 2016
    Texas
    Mine are built into the roof.
