A/C not cold
Discussion in 'General Camping Discussion Forum' started by Birdwoman26, May 12, 2016.
  1. Birdwoman26
    Birdwoman26 New Member
    33
    Apr 3, 2016
    First time out in NTU Aliner Expedition. Tried out the air conditioner. 78 degrees out but humid. It ran okay but never got cold. Any ideas?
  2. 94-D2
    94-D2 Happy Campin'
    2,281
    137
    May 21, 2010
    Sutter Creek CA
    Are you sure the compressor was running and not just the fan. If it is not getting cold, I suspect the compressor is not running. I have had a condition where the capacitor does not fire off and start the compressor. Usually after an on and off situation. Turn it on and see if you hear a secondary motor run that has a load on it. It should be apparent. The fan will sound higher and free running with no load basically. If it isn't Getting cold you have a problem.
  3. daschnoz
    daschnoz Active Member
    273
    56
    Feb 9, 2015
    I didn't stay at a Holiday Inn Express last night, but I do work for an HVAC company. I'm the guy that writes the equipment selection software that our sales force and building design engineers use to size and configure our equipment.
    http://www.poolpak.com/
    We had the same problem with our PUP last year.
    Low temperature (relatively speaking), high humidity - assuming that you don't have an electrical or mechanical problem with the A/C/ - I bet your A/C coil is freezing up. Most "quality" A/C systems have a mechanism that monitors the surface temperature of the cold coil. When the temperature gets below 33°F, it shuts down the compressor for a period of time to allow the temperature to come back up. BUT, these are not "quality" systems; they're made as inexpensively as possible and this is not an absolutely necessary feature to make the system function.
    Try running the heat while you run the A/C. It sounds counter-intuitive, but it will help keep the coil from freezing.
    If you're a nerd and want to know why, read on.
    The key with refrigeration systems is to follow the heat. Once I figured this part out, the function of refrigeration systems made perfect sense.
    A/C units do not cool the air. Instead, the air gives its heat energy to the cold side (evaporator coil) of the A/C. That heat is then given back to the air that blows through the coil on the hot side (condenser coil).
    There are 2 types of cooling loads that an A/C unit will see - latent and sensible. Sensible load is the measured air temperature that triggers the thermostat. Latent load is the heat energy that is stored in water vapor (felt as humidity).
    We all know that cold air holds less water vapor than hot air (this is why it is so dry during the winter). <-- This is important to the next part
    An A/C system needs a certain amount of heat input from the air (on the evap. coil) to function correctly. When the air is cool and humid, the available sensible heat energy is low, but the latent heat energy is high. As the air passes through the evaporator coil, water vapor condenses into liquid water on the surface of the coil. In a low temperature, high humidity condition, that condensed water vapor then gives its heat energy to the evaporator coil. The result - ice on the evaporator coil. The ice will block the airflow and give the illusion that the A/C is broken.
    Dehimidification is a side effect of refrigeration systems, and this is why. By running the heat with the A/C, you're adding more sensible heat energy to the air and giving the A/C more energy to pull from the air itself. It will still pull energy from the condensed liquid water, but since there is more sensible energy in the air, the coil will not freeze.
  4. drosengrant
    drosengrant One Day at a Time
    1,198
    22
    Jun 14, 2008
    Mine Hill NJ
    Daschnoz Interesting but thanks for the headache [:D] [:D] [:D] [:D] [:D]
  5. 94-D2
    94-D2 Happy Campin'
    2,281
    137
    May 21, 2010
    Sutter Creek CA
    That is exactly what I meant. [A]
  6. daschnoz
    273
    56
    Feb 9, 2015
    You're welcome. I did give fair warning.
  7. bols2Dawall
    bols2Dawall S.W. Ontario
    1,472
    164
    May 19, 2010
    Lasalle Ontario
    Are you saying the A/C unit was blowing cold air but the PUP never got cool , or ............?
  8. Birdwoman26
    33
    Apr 3, 2016
    The air was a little cool but it never cooled down the camper. We let it run a long time. Maybe it needs charged? It's an L G . the fantastic fan felt cooler.
    Sent from my Nexus 7 using Tapatalk
  9. bols2Dawall
    1,472
    164
    May 19, 2010
    Lasalle Ontario
    Eliminate any simple causes 1st , make sure the rear of the unit isn't obstructed , make sure the fins are clean and straight
  10. Dirtydozn
    Dirtydozn New Member
    May 1, 2016
    I have been an ac tech for 15 years. more than likely if the pup has been sitting for a while it is the capacitor. the cap is the most commonly replaced part on an a/c a lot of caps can dry up just like a car battery. you would know if it is working the air would be cold. take the cap out and test it if you can if not set it on a table if the bottom does not sit perfectly flush on the table its bad same goes for the top those systems are very simple. if you have a meter with an amp clamp put it on one of the main wires coming into the unit if the compressor is running you will have a higher amp draw if not it will probably read around a couple amps and that means compressor is not running bad cap. if it is running then its low on Freon. I would bet a thousand dollars it s the cap espescially if it has sat for a while any questions ask there is no ac I cant fix from industrial to residential
