a human expels a gallon of water in breathing per night?
Discussion in 'Heating / Cooling Systems' started by denemante, Apr 15, 2012.
  1. denemante
    denemante New Member
    56
    Apr 15, 2012
    When I was tent shopping long ago, someone told me that no matter what time of year - you had to keep windows open. This is to allow air to flow. He said a single person can breath out the equavalent of something like a gallon of water per night. If you close your tent up tight - it's got no where to go. Even worse if you have a bunch of people.
    So how might this work in a PUP? Do the roof AC units circulate air (and exhaust inside humid air to the outside in the process)? And what about the opt. heat setting on them (the "heat strip")? If that were bringing in colder outside air - it would negate itself.
    Is it perhaps that PUPs have larger cubic space inside vs. a tent, so this "breath humidity" isn't a concern?
  2. fmbhappycamper
    fmbhappycamper PuP Power
    4,325
    Aug 27, 2010
    I always open up a corner at least [8D]
  3. kitphantom
    11,813
    889
    Still true in a pup. You'll find threads in sections here on the "rain" in the bunk ends and the like.
  4. denemante
    56
    Apr 15, 2012
    Actually I just found in the manual it says to crack end bunk top windows just a tad. I could see that perhaps helping a tiny bit - but really not much cross venilation. What about something like a tiny computer fan tucked into an open window corner blowing air out? Or even one of the bunk-end fans? Leave all other windows shut. Not sure if the heatstrip is recirculating air or getting some from outside. But a pup isn't airtight - so maybe a tiny fan sucking the air out of the camper would help much more than just cracking windows.
  5. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    The heat strip has nothing to do with air. It is an electric device that just gets hot.There is no combustion so it requires no air nor gives off any moisture. You can think of a heat strip as a conveniently (yet improperly) placed electric space heater.As to opening the windows at night this is a must, a small fan expelling air will help but you are still going to get condensation if you don't have ventilation.What I do is unzip the entire top edge of the bunk end windows unless it is really warm then all windows are open.
  6. haroldpe
    haroldpe Campin' Engineer
    854
    Mar 21, 2004
    Adamsville, MI
    Hint: a gallon weighs around 8 pounds - looks like I found a new weight loss diet!! :)
    I think it's around a tenth of a gallon per (24 hour) day.
    Open those windows!
  7. kurtes
    kurtes Reno, NV
    640
    Jun 7, 2010
    Reno, NV
    When camping I may expel a gallon of beer at night, we live in a desert and I like to conserve water.
  8. RotnMom
    RotnMom Am I there yet?
    4,125
    19
    Apr 4, 2011
    Trust the replies!! I never had condensation in my tents. But when I bought the pup, and woke up to the water torture drips I nearly lost my mind thinking the canvas was leaking over my bunk!!
    Last trip out in the cold, I used my furnace, a small fan to blow the heat towards the front bunk and I wrapped the shepherds hook in a large Sham Wow. Opened the windows on each end of my bunk about 6"and haven't woken up all drippy since!! Now thats Sham WOW!!! :)):))
    Sorry, I couldn't resist!!
    ;D
    Sent from my DROIDX using Tapatalk 2
  9. Travelhoveler
    Travelhoveler New Member
    2,337
    Mar 8, 2011
    We always leave a vent open and window cracked, especially in cold weather. Otherwise, we get "the drips." From the camper roof, that is.
  10. denemante
    56
    Apr 15, 2012
    As per the condensation on a glass example - if it's 35 outside but 55 in the PUP - I understand the possibility of condensation on the inside tops of the bunkends. But does it work both ways, or is this normally a cold weather thing?
    Like if it's 85 outside at night, but the AC is cranked so it's 65 inside the PUP - could the same thing happen?
    I guess I'm asking what conditions are most favorable for condensation inside?
  11. Aladin Sane
    1,060
    99
    Jul 3, 2008
    Iowa
    I agree that people breathing in a pup can cause condensation on the inside of the canvas if proper ventilation is not allowed. What I don't agree with is the gallon per person claim. A gallon of water weighs 8.34 lbs. Do you really think a person can lose that much weight in a night of sleeping?
  12. denemante
    56
    Apr 15, 2012
    No, I was way off on the gallon...but with a few people it's a decent amount.
  13. Hacksaw
    1,875
    Aug 23, 2009
    I refer you to the defroster in the original VW Bug...it was was a direct vent to outside air.The theory? if the glass on the inside of the window is as cold as the glass on the outside of the window it cant frost...did it work? Yup pretty well (at least here in MN where it gets real cold)
  14. DSCinVegas
    DSCinVegas New Member
    627
    Sep 16, 2010
    If you are worried... Just move out here to the desert... mold is pretty much non existent here along with no fleas or mosquitoes... problem solved! [:D]
    Here is a little bit of mindless trivia--- do you know that Lake Mead evaporates an (average) over the year, 25,000 gallons of water EVERY SECOND!?! Obviously.. more in the summer... less in winter... but WOW!
  15. Unstable_Tripod
    14,279
    35
    May 20, 2008
    Seattle, Washington
    I read somewhere that it can be as much as a quart but a gallon is over the top. Regardless, open at least two windows across from one another a bit and you should have no condensation problem.
  16. rabird
    6,715
    307
    TX
    Water condenses on the cold A/C coils and drains on the PU roof, keeps the inside dry. :) The few times I've camped with A/C meant I could pack up a dry PU in the morning.
