A little hot under pressure
Discussion in 'Checkout My Rig !' started by Rickspald, Apr 20, 2020.
  1. Rickspald
    Rickspald New Member
    Nov 20, 2019
    So last month we took our rig out for its 4th adventure. Being an early spring the temps were getting up to the 70s and 80s. in GA. The tow vehicle is a 2000 Ford F150 extend cab 5 speed manual transmission. The truck is rated to tow 3,500 lbs. The trailer empty is 2,500 lbs. During our travels the temperature gauge kept rising especially when we were towing up hills. Believe me south GA along the "Fall Line" has pretty good hills. Even towing on the interstate with my foot heavy on the accelerator the gauge would rise to hot. If I back off the accelerator then the temp would go down. But then of course I would only be traveling at 55 mph. I'd like to be able to tow at 65 mph without any issue. I don't know if the thermostat is going bad or if I need one with a different temp rating?
  2. Raycfe
    17,458
    3,020
    You don't need a thermostat with a different rating, but you do need one that is working correctly. Replace it with the same rating would be the first step.
    Next step would be air flow thru the radiator. Have the fan clutch checked and the radiator condition.
    xxxapache likes this.
  3. Sjm9911
    9,359
    6,760
    My gmc had a sensor problem. It happened when towing and not towing. Depending on whats on your pup weight wise it could be overheating. Check the fluids and make sure the radiator cap is on tight.
  4. eoleson1
    eoleson1 Well-Known Member Gold Supporting Member
    3,478
    1,597
    Jul 5, 2011
    Macomb County Michigan
    Your thermostat is not the problem. The purpose of the thermostat is to maintain a minimum temperature. It has nothing to do with the maximum temperature. The most common cause of the symptoms you are experiencing is a clogged radiator. You can try spraying water through the radiator from the engine side. Maybe the fins are clogged with debris. There are other things you can try depending on the tools you have and your mechanical ability, or you could take it to a radiator shop for diagnosis.
    WrkrBee likes this.
  5. Aladin Sane
    1,145
    170
    Jul 3, 2008
    Iowa
    I think a flush of the radiator internals would be more effective than hosing off the fins.
  6. WrkrBee
    5,721
    2,931
    Ever been to Florida when the Love Bugs are out? Bugs at night can be thick and the big ones can bend fins, decreasing a radiators efficiency. Why not do a simple cleanliness check before doing a flush? A flush can cause leaks, depending on the condition of the system, since a flush uses some pretty harsh chemicals.
  7. Snow
    11,469
    2,082
    Here is another suggestion.. just drive at 55.. unless you have higher rated trailer tires, majority are only rated around 55 to 60 mph anyways..
  8. Anthony Hitchings
    2,468
    1,377
    Mar 2, 2019
    Oakland, California
    when on the interstate and not towing is the temp gage stable? If yes, then maybe its not the thermostat
    Fyi - temp gage in our 2008 jeep liberty 6-speed manual is rock solid at dead center, towing or not. Best vehicle we have ever owned in that regard
  9. eoleson1
    3,478
    1,597
    Jul 5, 2011
    OP could try this, but normally if a radiator gets internally clogged, water pressure is not enough to clean it. In the old days we would take the ends off of the radiator and run a rod down each tube, but you can't do that with a modern plastic/aluminum radiator.
  10. firepit
    firepit Well-Known Member
    2,122
    3,159
    Feb 26, 2020
    Nebraska Go Big Red
    With a 20 yr old truck and assuming higher miles a new thermostat and coolant flush would be a wise move.
    If it has a clutch fan...That should be checked as well.
    Radiators are not that expensive in case you have one that needs replacing after 20 yrs of use.
    1380ken and xxxapache like this.
  11. Sneezer
    2,666
    1,499
    I would echo this. The few times I have had temp rising issues were due to a poorly maintained cooling system. System needed flushed, bad thermostat, bad fan unit, gasket leaks, etc.
    firepit likes this.
