AAAARRRGGGGG!! Am I the only one??!!
Discussion in 'Tires / Brakes / Bearings / Axles' started by Milemaker13, May 11, 2019.
  1. Milemaker13
    Milemaker13 Active Member
    205
    90
    Apr 28, 2019
    Suburbs of Chicago
    Putting the trailer bearings back together.... last step- just pop the cap on the hub. Thats the easy part... right?
    WRONG!!!!
    I have never had good luck getting these dang things on. Previously installed ones seem a little easier.. but brand new ones?? Forget about it! I always struggle and end up beating the heck of of them. So much for new ones.
    What tips or tricks do you have? No, not " use a piece of wood to avoid denting them"...
  2. SteveP
    SteveP Well-Known Member
    1,607
    460
    Keep it even. Don't try to drive it in all at once. Gentle taps. I prefer a rubber mallet to a steel hammer.
  3. Anthony Hitchings
    853
    378
    Mar 2, 2019
    sometimes they re not exactly the right size - very frustrating
  4. Milemaker13
    205
    90
    Apr 28, 2019
    Suburbs of Chicago
    That seems possible i guess. This time in particular these are new hubs from etrailer and new bearing kits (w/ caps) from etrailer.
    It is very frustrating!
    Maybe Ill contact them and ask their advice.
    Oh, btw- I'm not exactly a stranger to mechanical things being a maintenance mechanic and electrician for over 20 yrs now (that on top of a childhood of crankin' on broken lawnmowers, bikes and go carts) so yeah... I'm pretty good ;)
  5. jeeper88
    jeeper88 Let's go Camping and Jeepin
    884
    63
    Apr 24, 2011
    Ocala,FL
    LOL one wack with a 20lb deadblow ought to do the trick!!!!! ;)
  6. nineoaks2004
    7,754
    3,405
    Dukes, Fl
    I have an old socket that just fits the lip I place this over the cap and tap it in with a rubber hammer it all goes on evenly this way
    Milemaker13 likes this.
  7. davekkk
    davekkk Active Member
    452
    44
    Oct 7, 2013
    Wisconsin
    They never look as nice after I repack the bearings!
  8. WrkrBee
    WrkrBee Well-Known Member
    3,211
    1,335
    Find a piece of pipe that fits on the flange, weld a round plate to the other end for pounding. Sometimes it takes pliers to just slightly give the lip a little extra bend in.
  9. Milemaker13
    205
    90
    Apr 28, 2019
    Suburbs of Chicago
    Yep ok.. this is that i was thinking. Monday I will make an install tool out of pipe as described above.. also while at the lathe I will attempt to roll a slight inward bevel on the cap. Those two things should ease my troubles... oh course I had to bash one new cap in before using my head here (and yours!) .
    " When I nod my head, you hit it! "
  10. LittleBrother
    LittleBrother New Member
    Feb 1, 2017
    Glenn Dale. MD
    Tip I read for bearing buddies was put them in the freezer, get the metal cold to shrink it up a little. Might be worth trying for the regular caps as well.
    1380ken and Milemaker13 like this.
  11. Milemaker13
    205
    90
    Apr 28, 2019
    Suburbs of Chicago
    I used a 2" pipe nipple to put the old ones back on. The new ones just would not go.
    jnc likes this.
  12. SpecialGreen
    SpecialGreen Member
    48
    19
    Jul 5, 2018
    I've had that problem... and also the exact opposite problem, where the bearing caps fall right off after you put them on (I have had to bend them slightly out-of-round so that they stay on). I don't think the caps and hubs are manufactured with consistent tolerances.
  13. bheff
    bheff Well-Known Member
    1,498
    894
    Feb 24, 2011
    NW Arkansas
    I will slightly bevel the edge on a grinder. It seems like the coating on them make them just a tad thicker in diameter, causing frustration. 15 seconds on a grinder and all is good.
  14. neighbormike
    2,549
    2,050
    Oct 6, 2012
    WI
    My advice: keep the old ones lol... new ones never seem to fit... even when they're the "right" size!
  15. Milemaker13
    205
    90
    Apr 28, 2019
    Suburbs of Chicago
    I ended up chucking them in the lathe(gently of course!) And using a file to bevel the edge. Then they went in relatively easy.
    bheff and neighbormike like this.
  16. WrkrBee
    3,211
    1,335
    Make sure you wash them out after grinding. You don't want to make a lapping compound out of the grit mixed with grease.
  17. Anthony Hitchings
    853
    378
    Mar 2, 2019
    yup, been there and done that
