AC Help, please.
Discussion in 'Heating / Cooling Systems' started by Shaman1, Aug 5, 2019.
  1. Shaman1
    Shaman1 Well-Known Member
    2,237
    509
    May 13, 2011
    Oklahoma City, Oklahoma
    The AC on my hybrid keeps popping the circuit breaker. Before this last trip, I removed the outside cowling cleaned everything and replaced the inside filter. During this trip it would pop the breaker after about 30 minutes, never on start up. I turned the fridge on gas and had nothing else 110 running. I removed the inside cowling and nothing was obstructing the blower fan or the inside intake. With the inside cowling off, the AC ran all night without problems. What should I check or replace? Thanks! Steve
  2. SteveP
    SteveP Well-Known Member
    1,537
    424
    Most likely the compressor start capacitor. At startup the lines are at nominal pressure and it doesn't take that much to get the compressor started. The compressor may stop and restart during operation, that restart, with pressure already in the lines takes a lot of juice.
  3. Shaman1
    2,237
    509
    May 13, 2011
    Thanks so much. AC is one area I don't know well.
  4. joet
    4,817
    982
    Ant way to check AMP draws? Thats the quickest way to tell what's going on
    nineoaks2004 likes this.
  5. Shaman1
    2,237
    509
    May 13, 2011
    Thanks SteveP. Replaced the compressor capacitor and all is well. I was dreading the thought of an RV dealer.
