AC/Roof Maintanance
Discussion in 'Roof/Floor Repair & Maintenance' started by opie232, Sep 24, 2014.
  1. opie232
    opie232 Member
    283
    Mar 1, 2013
    [?] Anyone have any advice on how to reseal the AC on the rooftop? I have a small leak and would like to know the best way.
  2. Ryanincc
    2,275
    Dec 28, 2013
    Corpus Christi, TX
    Im interested too. I thought they werent sealed, and it was only the gasket that needs replacing fro time to time.
  3. Raycfe
    15,248
    1,451
    The A/C has a thick foam gasket that should be changed time to time. First thing to check is if the bolts are loose. Remove the ceiling unit and the mounting bolts should be there. If the gasket is three or four years old I would buy a name brand good replacement seal and change it. Plan on resealing the center seam at the same time.
  4. opie232
    opie232 Member
    283
    Mar 1, 2013
    Thanks. I plan on ordering a gasket today and had already planned on resealing the center seam before falls end.
  5. opie232
    opie232 Member
    283
    Mar 1, 2013
    For resealing the center seam I found a product called Eternabond. Is this what you would use or is there a factory option I should look into??? [?]
  6. Heritage
    Heritage New Member
    199
    Jul 6, 2013
    No Eternabond is awesome. Lots of info on the forum about it.
