AC Vent Redirector
Discussion in 'Heating / Cooling Systems' started by cottonlily, Sep 12, 2019.
  1. cottonlily
    cottonlily New Member
    Apr 1, 2019
    Full disclosure - I may have just made that term up. Our pu has the rooftop ac but that's where all the air blows, back up on the ceiling. It certainly cools the pu but it would be much more comfortable if some cool air would blow downward and I think we wouldn't have to run it as much/high. It has the factory diverter in the vent opening but it doesn't help much for this purpose. I can't find anything specific so willing to DIY. Any ideas? Something akin to the exterior vent for a clothes dryer and some heavy duty adhesive maybe.
  2. BikeNFish
    BikeNFish Well-Known Member
    2,986
    1,895
    Apr 24, 2017
    Maplewood, MN
    I don't have AC on my pup but if I wanted to deflect the direction of the air flow, i would start with trying to duct tape a piece of cardboard to the ceiling about 6 inches away from the AC vent to see if I could deflect it downward.
    eoleson1 and cottonlily like this.
  3. Pnut
    Pnut Member
    76
    36
    Jul 8, 2018
    NE Georgia
    I added a vent in that blows out the bottom that you can turn and direct it where you want to. Here is a link to something like I did.
    [​IMG] [​IMG]
  4. nineoaks2004
    7,403
    3,143
    Dukes, Fl
    I have had a couple of units with window airs on the floor , I used Luan plywood, Glue and made a diverter that moved the air upward made a big difference
  5. BillyMc
    BillyMc Well-Known Member
    1,224
    581
    Mar 25, 2018
    Not sure what you're looking for here. Ours has four vents. We aim one into each bunk and the other two down sharply and it works pretty well. The only time I recall running it on high was a trip in July 2018 where the afternoon temps were 100+ every afternoon.
  6. Sneezer
    1,547
    543
    Not sure how yours is configured - mine has vents that you can move, but they refuse to stay in one spot, and always end up rotating back up to the ceiling. I ended up using a folded piece of paper to make a wedge that kept it in a mostly downward angle. That simple mod did make a difference, along with a number of fans in the cabin to help circulate the air a little more as well.
  7. HappyTraveler
    HappyTraveler Active Member
    328
    224
    Apr 30, 2019
    New York
    Saw somewhere on here where someone used one of those flexible cutting mats to divert the air. It's slim enough to fit between the ceiling and the ac framing. You could rig some sort of wedge type of thing that would fit between the cutting board and ceiling to bend the cutting board down where you want it.
    Here's a link to the type of cutting board used: https://www.bedbathandbeyond.com/st...hKqo4jJCay9NL7xQwYBoCZ9EQAvD_BwE&gclsrc=aw.ds
  8. Sjm9911
    4,734
    2,469
    I use the bunk end light fans, it pulls the air toward the bunks.
