Actual dimensions for Jayco 1207 "beds" anyone???
Discussion in 'Cushion, Curtains, Carpets, Bedding, Clothing Stor' started by reidsd, May 3, 2011.
  1. reidsd
    reidsd Kelowna, B.C.
    269
    Jul 11, 2007
    Kelowna, British Columbia, Canada
    To any and all. We are interested in adding air mattresses under the standard PU mattresses that came with our Jayco 1207. However, I have looked on line for the actual measurements for the sleeping spaces for our PU in order to find the "right" sized air mattresses. I just can't find the measurements. Does anyone know what they are???? We have one "king", one "queen", one U-shaped dinette that converts to a "bed" and then a second non-U-dinette that converts to a "bed". I know that I can set up the PU on the driveway, grab my tape measure and got to it, but given the weather we have been experiencing, I haven't had the right time to do it. I was hoping some member of the portal has already made this mod and would and understand my situation.
    Thank you to any and all that respond. I look forward to hearing from anyone.
    Scott
  2. bitva
    bitva New Member
    Jan 12, 2011
    I think it's a king on one end (the front, above the hitch) and a queen on the other. A quick look on the jayco site should tell you for sure.
  3. reidsd
    269
    Jul 11, 2007
    Thanks bitva. It is but it isn't. I knew that Jayco called them a king and a queen, but often the PU mattress size is not exactly the same as a regular mattress size. I want to get properly sized air mattresses (airbeds) for under the PU mattress as has been suggested by other PU portal members. We had a nice day yesterday so I actually hauled the PU up the driveway, set it up and took the actually measurements. I had to do this because when I called Jayco itself from work the other day, they told me that they could get me the information, but only after I gave them the VIN number; the model number and year wasn't good enough. Well, all of that information was at home. So up the PU went. Anyway, the queen is actually fairly close to a queen. The king, isn't quite a king but I think a king air bed will work with just a bit of an overhang. The U-dinette is closest to what Coleman calls an SUV/Truck airbed (not quite a twin). The other dinette isn't close to anything. Anyway, now that the PU is set up on the driveway, I can move forward with the airbeds and then some other de-winterizing, cleaning up (spring cleaning).
    Scott
  4. Yooperwannabe
    Yooperwannabe Active Member
    1,976
    Mar 31, 2006
    Clinton, Illinois
    So tell us.... what are the exact measurments?
  5. reidsd
    269
    Jul 11, 2007
    Sorry. Didn't realize anyone was actually interested. I have the measurements at home so I will post later today. Stay tuned.
    Scott
  6. reidsd
    269
    Jul 11, 2007
    Okay, for those that are interested, here are the dimensions, in inches, of the sleeping areas in the Jayco 1207:
    King - 77 long x 70 wide (based on slide out; could go 2-3 inches longer)
    Queen - 77 long x 60 wide (ditto on a bit longer)
    U-dinette - 80 long x 49 wide
    dinette - 62 long x 36 wide
    Hope someone out there finds this information useful.
    Here is my plan: will/have purchase one Coleman 4 in 1 airbed (two twins that lash together to be a king; can't get the king in canada), one coleman queen quickbed airbed, one coleman SUV/Truck airbed for the U-dinette and nothing yet for the regular dinette. Not perfect but it should be an improvement over the standard PU mattresses. We are going to be living in the PU for 24-25 days this summer and on the road for about 14 of those days so I am going to need my sleep!!!
    Happy camping.
    Scott
    Thatslikewhen likes this.
  7. Thatslikewhen
    Thatslikewhen New Member
    Jul 11, 2019
    This is very helpful, I just ordered my bedding based on the dimensions you listed. Thanks!
  8. Teaston
    Teaston New Member
    May 3, 2020
    Thank so much I couldn't find these measurements anywhere else.
  9. MNTCamper
    MNTCamper Well-Known Member
    1,090
    325
    Jun 14, 2014
    MN
    Just a couple of additions. I get 78" long on the ends and that is the actual mattress measurement. The u shaped dinette is shorter by 2-3". Overall, I'm confused on the air mattress thing. Just add memory foam to the existing mattresses if there is a comfort issue. We still sleep on our original mattresses, but they are too soft overall, but we do fine out for 10-22 days. We do have 3/4" of extruded polystyrene under our mattresses for insulation, it doesn't change the way the mattress sleeps.
  10. Susanocsd
    Susanocsd New Member
    Sep 6, 2015
    San Antonio, Texas
    Nearly 13 years later. Your reply is still being helpful. I have the 1207 UD and preparing to go on an extended camping trip during the pandemic. Need to improve the sleeping Arrangements on my side, cuz at 59 I can only go with a couple of nights bad sleep. My kids are only 13 and 15 I can sleep on and through anything. Planning on installing memory foam mattress topper on my side.
