Add a hitch?
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by rangerover, Mar 6, 2018.
  1. rangerover
    rangerover Member
    95
    Jun 1, 2013
    I want to add a 2" trailer hitch receiver to my pup so I can use my trailer hitch mounted bike rack. Anyone ever do this?
    Flamingo Guy likes this.
  2. BikeNFish
    BikeNFish Well-Known Member
    3,440
    2,324
    Apr 24, 2017
    Maplewood, MN
    I have not, but I have heard that you need to be careful how you do it. Most bumpers on pups aren't designed to carry any weight.
    rangerover likes this.
  3. Snow
    10,802
    1,525
    General consensus here and just about every other camping board.. Do NOT do this.. A pups bumper is not designed for it and all the extra weight from the bikes will increase the chance of sway...
    That said... it can be done, but has to be done properly .. First you have to re-enforce the bumper, bumper attach points and the receiver you'll be adding.. Once the bumper is re-enforced, you have to have the bumper attach points welded into the main frame rails ( these are the two frame parts that the axle/springs attach to.. the receiver will have to be welded into these frame rails as well .. Second, for every pound you add the rear of the pup (anything aft of the axle) youll have to add the same amount of weight to the tongue..
    If you look (search) this site youll find tons of info on this idea as well as other ways to carry bikes...
  4. kitphantom
    12,287
    1,280
    Unless done properly, you chance damaging the bumper, bikes, etc. There has been more than one report of people starting off and having the bikes land on the road. It can also lead to sway, and may change the balance of the camper.
    When we took the bike with the pup, we used a carrier on the back gate of the 4Runner. Since we had a Thule cargo box on the roof, there wasn't room for the bike there too. There are carriers that mount to the pup so the bikes are carried on or over the top of the camper. There are also tongue mounted ones, but again you have to worry about balance.
    (Now that we have the TT, we can carry the bike inside. We just have to remember to take the hitch rack along too. We forgot that on the first trip with the bike/TT combination, which limited the trainload choice.)
    Here is a section to read: http://www.popupportal.com/forums/cargo-carriers-bike-racks-other-storage-option.55/
  5. Halford
    Halford Well-Known Member
    3,563
    568
    Sep 28, 2011
    Santa Clarita, California
    the bike rack would need to be attached to the frames, not the bumper.
    If you like to sway, go for it... I would not do this.
  6. BikeNFish
    3,440
    2,324
    Apr 24, 2017
    Maplewood, MN
    I do a lot of biking and have been researching the best system for me to carry my bikes. So far, THIS is the system that I am leaning towards.
    My only hesitation is that I'm not very excited about bikes bouncing around on the top of my pup. A tie-down may be the answer, but would this cause the tires to dent my roof?? Hence, my hesitation.
  7. Halford
    3,563
    568
    Sep 28, 2011
    ahhh on roof? better roof of your TV.
    rangerover and jnc like this.
  8. J Starsky
    J Starsky Well-Known Member
    840
    642
    Aug 3, 2017
    East Central MN
    My old pup has a bike rake on the spare tire assembly. Unless you can add a receiver on top of the frame, don't attach it to the bumper.
  9. rangerover
    rangerover Member
    95
    Jun 1, 2013
    Thanks everyone, I am surprised that it would cause sway.
  10. Wrenchgear
    3,459
    719
    Aug 5, 2010
    5 Star Eagle Camper
    Anything that adds weight behind the axle removes tongue weight. The farther back the weight gets, the more weight is removed from the tongue. When the tongue gets too light, you get sway.
  11. Snow
    10,802
    1,525
    Here is a very good explanation on sway ...
  12. myride
    myride Well-Known Member
    1,061
    528
    May 14, 2015
    Edmonton, AB
    I've using that system for 3 yrs now.....no bounce and no roof damage. Increase in tongue weight is minimal.
    If price is a concern many have home-built using this design....just search bike carriers.
    rangerover and BikeNFish like this.
  13. fdmsiv
    fdmsiv New Member
    Mar 14, 2017
    I just noticed etrailer has some interesting options depending on your budget.
    Tongue Mount
    https://www.etrailer.com/RV-and-Camper-Bike-Racks/Stromberg-Carlson/CC-275.html
    Rear Bumper Mount
    https://www.etrailer.com/RV-and-Camper-Bike-Racks/Swagman/S80500.html
    Both are bolt on, the tongue mount (after removing the bike holder) might fit under the bunk... Regarding the sway issue, you have to consider the distance between the axle and the hitch. The above video is 100% correct however a little misleading in that the distance from the axle to the hitch is generally greater than the distance from the axle to the rear bumper. If compensation is needed it won't be 1:1 but probably 50 - 75% of bumper added weight depending on placement.
    All that being said I am considering one of these:
    https://www.harborfreight.com/Dual-Hitch-Extender-69881.html
  14. Sneezer
    2,119
    952
    I just found one of these by the dumpster on my last campout. Haven't had a chance to try it out yet, but hoping it will work well with my hitch mounted bike rack.
  15. Snow
    10,802
    1,525
    Just beware, many of those hitch extenders cut the tow rating and tongue weight rating of your hitch by as much as 50%..
    kitphantom likes this.
