Added Storage for pup
Discussion in 'Cargo Carriers / Bike Racks / Other Storage Option' started by Bradley E Dixon, Jul 11, 2020.
  1. Bradley E Dixon
    Bradley E Dixon Member
    53
    73
    Jul 1, 2019
    Minot, ND
    Ahh another project almost wrapped up.
    Been trying to sort out how to maximize the space available to haul gear for setup and teardown . Most of what we needed took up a lot of space in the truck, and required considerable time packing and unpacking when we decided to head out. I wanted to be able put all the gear somewhere and leave it with the camper in one place......
    Took advantage of one of my coworkers who put his awesome 15+ years of fabrication skills to work and welded in a new 2" hitch receiver with reinforcement from 13/16" - 1 1/2" angle iron to my existing rear bumper and boxed camper frame. (Heavier frame due to its toyhauler capabilities...but unfortunately has a really light- weight bumper)
    After that he helped me install my new cargo carrier/cargo box combo. Secured with a hitch stabilizer and a little paint.....
    It doesn't move...at all. The whole objective was to make sure there wasn't any "bounce" in the assembly....and there isn't.
    All I have to me mindful of is that I'm a little longer when towing.
    Wanted to share.
    fronsm, Fishpit and Sjm9911 like this.
  2. Ductape
    Ductape Well-Known Member
    1,238
    259
    Jun 12, 2013
    Awesome !
  3. nineoaks2004
    8,213
    3,676
    Dukes, Fl
    Looks and sounds like you have found an answer to your storage problem. Remember when you load the box that tongue weight (at least 10% ) is important to keep the unit from swaying
  4. Bradley E Dixon
    53
    73
    Jul 1, 2019
    Minot, ND
    I should add that when I first bought this pup to address the limited storage, was when I added the front Carlson RV front cargo tray last fall to haul my generator
    But due to the configuration of the pup's front hitch I was unable to use all the mounting/bracing hardware, so I ended up using a small ridgid tote to put gear in.
    Unfortunately, it wasn't big enough to haul some of the gear/accessories we needed
    I not planning on throwing 500lbs creating unfavorable weight distribution or sway when towing.
    The front open 9ft deck still has lots of room and cargo weight capacity if I only haul one of my 700LB ATVs.
    Oh I forgot to mention that I can relocate the rear box to the front deck if need be and fold up the carrier into a "transport" mode.
    It's all good
