My pop up has straight sides, as in the wall is continuous over the wheel well, which makes changing the tire nearly impossible. It takes a lot of maneuvering and a few choice words to get the tire in there, and it has to be devoid of air pressure as well.
I have looked inside the wheel well, and there appears to be a small section of angle iron, and a piece of sheet metal inside to support the outer sheet metal.
would it be okay to cut these out and put on a fender skirt to add access to the wheel?
