adding ac to a 1980 Jayco
Discussion in 'Heating / Cooling Systems' started by madmatador78, Jun 14, 2015.
  1. madmatador78
    madmatador78 New Member
    Apr 21, 2015
    Hello all,
    I have been contemplating how to add ac to a 1980 jayco j-flight 6. The camper is in awesome condition for its age and I would really like to keep it. I would like to avoid any hacking into the sides of camper if possible. Plus space is at a premium in this unit, So window unit is out. There seems to be mixed reviews on weather a portable ac with a vent would do the job. Not to mention the extra cost.
    I know this may be a bit much, but could I make the roof be able to support a roof top unit? I have already upgraded the service to 30A, so power would not be a problem. My concern would be the roof and the cable system being able to support the extra weight. If they could be beefed up so to speak, then I would like to pursue this route. Can this be done? Or is this just a pipe dream?
  2. jeeper88
    jeeper88 Let's go Camping and Jeepin
    804
    31
    Apr 24, 2011
    Ocala,FL
    can u post a pic of ur in and outside roof
  3. George Rose
    George Rose Member
    243
    Aug 7, 2013
    We originally had a smaller Jayco. I bought a small window unit Air conditioner. I took an aluminum folding walker and added PVC pipe to the bottom of the legs. This allowed me to use the adjustments on the legs for uneven ground. I screwed a couple pieces of wood across the handles of the walker and set the a/c unit on that. Inside I cut an opening in the window vinyl the same size as the vent on the a/c unit. A little bit of foam weather stripping around the edge of the a/c unit allowed a snug fit right up next to the side of the pup. Yes this is redneck as hell but it worked for 3 years until we bought a bigger pup with rooftop air!
  4. Jeepguy93
    Jeepguy93 Active Member
    496
    29
    Mar 30, 2014
    MA
    I have a 90's jayco I added a rooftop ac to the existing vent hole. However my coleman had no vent plus its in good gondition... so I had an extra ac and some other stuff laying around the house I constructed a crappy trial version of this.
    If it works in the test trail, ill get some insulated ducting and fabricate a sheet metal cover for the ac, along with a plate that mounts to the camper for the ducting. I only really care at sleeping time about temp and humidity.
  5. George Rose
    George Rose Member
    243
    Aug 7, 2013
    That looks as bad as my walker !
  6. Jeepguy93
    496
    29
    Mar 30, 2014
    MA
    At least I have AC.
  7. Jeepguy93
    496
    29
    Mar 30, 2014
    MA
    HAHA yes its pretty odd looking. My brother enjoyed making fun me the enitre time, he also ejoyed the ac. He won twice.. [:(!]
