Adding Brakes?
Discussion in 'Camper Restoration Projects' started by Beckymeep, Jun 25, 2018.
  1. Beckymeep
    Beckymeep New Member
    Jun 14, 2018
    Hi,
    I was looking in to the tow capacity of my vehicle and wanted to know if anyone had ever added brakes on to their trailer? I'm looking at a 1975 Coleman Patriot, and would like brakes on it, if that's possible?
  2. Fuzzy Bear
    Fuzzy Bear Active Member
    506
    106
    Mar 3, 2004
    Norwalk CT
    What are you towing with? I just did a quick search (not familiar with the patriot) and it looks to be a fairly lightweight trailer. Brakes can be added I believe you have to change out the wheel hubs as well as wiring them up and adding a brake controller to your vehicle. I'm sure others will chime in that have a lot more experience with it than I do (the tow rating for my GMC is 3500# and my little coleman Columbia weighs in around 1000# so I never found the need for brakes).
  3. Beckymeep
    Jun 14, 2018
    Hi, I have a Suzuki Sidekick JLX and it can tow up to 1000lbs, the Patriot (if it is a 75, like owner said) is 810lbs, if its a 76 its 990lbs. But with a propane tank, battery as well as our stuff for camping, the weight would be up to the max! I also preferred a less beaten up Columbia I've seen but as you said they are at my max from the off. I read if the trailer has brakes my Sidekick can tow up to 1500lbs.
  4. joet
    4,832
    984
    Add the Brakes, you will need them since you are towing at or above capacity
  5. mstrbill
    mstrbill Active Member
    692
    145
    Mar 17, 2013
    Austin , Texas
    Is it a 2 or 4 door? Not sure I would to be over my tow rating with a 2 door. And what's the hitch rating on the sidekick.
