Adding hooks to ceiling?
Discussion in 'My Favorite Mods, Tips, Tricks (and Blunders!)' started by Limmer, May 30, 2019.
  1. Limmer
    Limmer Member
    47
    25
    Mar 12, 2018
    Ontario Canada
    Hey everybody. Just got our PUP and trying to figure out space and storage. We want to hang those 5 compartment organizers from the ceiling but are not sure what we should use to attach the hooks to the ceiling. We want it to hold but not to damage it. Any suggestions?
    **I should have clarified we do not want to drill holes. I was thinking some sort of adhesive.
    HappyTraveler likes this.
  2. CampingFamily1
    CampingFamily1 Active Member
    865
    229
    May 12, 2007
    Minneapolis/St. Paul, MN
    I had my dealer install those. They use a special fastener that doesn't damage the precious roof.
    HappyTraveler and Limmer like this.
  3. Sjm9911
    6,895
    4,263
    I hang stuff on the sheperds poles, shower curtian rod and a shoe orginizer on the door. I did make the pressure rod shelves to go over the sink. I would be Leary of anything that wasnt screwed through the roof if you want to put anything with a little weight in it. That being said, i would not put a hole in the roof eaither. Gorilla glue will stick to most surfaces. Check out some storage mods, there are a ton and you might like some of them better.
  4. CampingFamily1
    865
    229
    May 12, 2007
    I think the dealer uses a perfectly sized special screw that just goes through the ceiling, but not into the roof. You could call my dealer's parts or service department or Beckley's (both top rated dealers) during a slow time of the day, and they would know the exact size and type of screw it they use for this.
  5. jmkay1
    5,629
    2,430
    I managed to find a shower curtain rod that can extend just in front of the bunk end. I was then able to hang a sweater organizer from that. I also cut a shoe organizer and attached Velcro to it and attached it to the bar on the bunkend. Great place for keys, cell, book. I personally didn't want to put anything on the ceiling and doubted glue could hold much stuff. PhotoPictureResizer_190530_172031669-1312x738.jpg
    HappyTraveler and Sjm9911 like this.
  6. roybraddy
    roybraddy Well-Known Member
    2,354
    886
    Mar 23, 2016
    King George, Virginia
    My POPUP trailer has one of the ceiling pull down hanger holders on one end. It is pretty close to the edge of the ceiling so I guess that add's some strength to the ceiling. My ceiling board is 1/4-plyboard...
    It is just below the left hand arrow shown here...
    Google image
    If I was going to support something heavy I would install something across the whole ceiling and tie into the roof sides like shown in one of the posts above... These will hold some screws or something sticky...
    Roy Ken
  7. CampingFamily1
    865
    229
    May 12, 2007
    This camper caddy is attached with 3 specialized bolts. It holds quite a bit of weight distributed among 3 fasteners into the ceiling. I imagine there is a 1/4" plywood ceiling, then 1" thick foam, then finally the precious roof glued onto the foam. This all requires expert knowledge of how far you can drill through the plywood ceiling, into the foam, without touching the fiberglass roof. And it needs a perfectly sized expanding bolt that doesn't go too far, but gets through the ceiling. I had my dealer install these bolts on both sides of my camper while it was still covered under warranty. They recommended I have them install it since it required specialized knowledge.
  8. Sjm9911
    6,895
    4,263
  9. Sjm9911
    6,895
    4,263
    The one in my camper.
    HappyTraveler and CampingFamily1 like this.
  10. bheff
    bheff Well-Known Member
    1,504
    915
    Feb 24, 2011
    NW Arkansas
    They make Command strips that can hold some serious weight. And they can be removed if you dont want them anymore
  11. LittleBrother
    LittleBrother New Member
    Feb 1, 2017
    Glenn Dale. MD
    I put screws in my roof for a hanging organizer and basket, used #6 x 1/2" screws to attach some small footman loops and hang organizers from that. The lights, hanging bar (assuming you have one), and A/C power cord are all held up with screws from the factory. I've had no problems.
  12. CarlaCB
    CarlaCB Member
    46
    39
    Apr 8, 2019
    Central Florida
    This is a great idea, but it's not clear how you hold it in place. Does it use tension against the sides of the roof, or did you install rod sockets, or what? Also, can you close the camper with it in place, or do you need to take it down? Thanks from a newbie.:smiley:
  13. jmkay1
    5,629
    2,430
    On mine it's a combination of tension and being supported by my curtain tracks that run all the way to the end on my camper. If I didn't have the curtain tracks I would have just glued rod holders on the side. I'm able to leave it up all the time and don't even have to take the organizer down as it folds down with the camper. occasionally I may have to tighten the tension on the rod but I've had it up for three seasons and it held up fine. Now I try not to overload the bar with too much heavy stuff and keep the organizer towards the side of the camper vrs center of the rod. You will need something to hold the rod though. The roof flexes and moves quite a bit and tension alone would cause it to slip. It comes in handy. I hang damp towels to dry, heavy coats. The sweater organizer is my pantry and clutter holder. I chose this route as I didn't want to have to disassemble/reassemble shelving every trip. I'm of the keep it simple crowd.
  14. CarlaCB
    CarlaCB Member
    46
    39
    Apr 8, 2019
    Central Florida
    Thanks. That's exactly what I needed!
  15. HappyTraveler
    HappyTraveler Well-Known Member
    432
    308
    Apr 30, 2019
    New York
    When I took down all my valences and curtains, I found 3 of these clips up around the ceiling between the roof and shower curtain track. Wondered what they were for and now I know!
    Thanks for sharing this photo!
  16. Minimalist
    Minimalist Active Member
    251
    49
    Nov 30, 2015
    We use hooks with very strong magnets that we attach to the support bars for the AC. The magnets are seriously strong. Keep them away from children because they can badly pinch little fingers.
  17. Punkndoodle
    Punkndoodle New Member
    Feb 12, 2019
    CarlaCB likes this.
