Adding power winch
Discussion in 'Lift Systems' started by mruss1993, Sep 1, 2009.
  1. mruss1993
    mruss1993 Clarksville Tn
    102
    Jan 19, 2009
    clarksville tn
    We have a 1993 Jayco Cardinal 16 ft box on it and I have finally purchased the power winch to convert the lift over......Gonna try and work on it the next few nights if time permits but definately hope to be able to have it done by saturday by the latest...... [:D]
  2. Crazycoleman
    Crazycoleman It is so much better when you wake up IN the pup!
    142
    Sep 21, 2008
    Henrietta, Tx
    That is awesome. What kind of winch did you get? We have a manufacture here where I live that builds all kinds of winches, and I can get a refurbished ATV winch from them for 50 bucks. I have been thinking about making that addition.
    ROb
  3. jmullan99
    jmullan99 New Member
    289
    Sep 7, 2008
    Niagara Falls, ON
    Good stuff! I love the winch I added to my 73 Starcraft. Life is so much easier.
    Cheers
  4. mruss1993
    102
    Jan 19, 2009
    clarksville tn
    Ok, got the winch put on just does not seem to have enough to raise it all the way, I was thinking that I read somewhere that You have to remove all the excess cable off of the spool, just want to be sure before I do......I would have thought that a 3000 lbs winch would be enough to raise the roof.....
  5. Hacksaw
    Hacksaw Active Member
    1,875
    Aug 23, 2009
    Possibly a limit switch on the winch? Just a thought
  6. jmullan99
    289
    Sep 7, 2008
    Niagara Falls, ON
    You are correct. The winch will be rated 3000lbs at the best ratio. IE; up to the first layer of cable. As the layers build, the ratio decreases, like gears.
    I had the same issue until I removed all the cable except the length needed for full lowering of the roof (and a small bit extra) but the entire amount was not even one complete layer of cable on the spindle.
    Don't worry either. There will be plenty of spare cable you cut off to do it over again if you make a mistake.
    Cheers.
  7. mruss1993
    102
    Jan 19, 2009
    clarksville tn
    I really hope that that is it, my old lady( i mean dw) will kill me. if i don't get it right
  8. Hacksaw
    1,875
    Aug 23, 2009
    Just out of curiosity where is the winch mounted? I don't know anything about the Jayco lift system and am trying to wrap my head around how it would work.
  9. mruss1993
    102
    Jan 19, 2009
    clarksville tn
    My winch mounts under the door side seat, the manual crank went in the front of camper through the access hole. So I mounted it right to the existing bracket.
  10. rawhite1969
    rawhite1969 Always happy when camping.
    52
    Sep 12, 2009
    Indianapolis IN
    does the winch need any kind of stop mechanism for when the unit is cranked up? Or would the tension on the winch be sufficient? WOuldn't want it releasing and letting the roof down. Any input on that? Or a spec on the type of winch needed? This mod sounds great and affordable!
  11. jmullan99
    289
    Sep 7, 2008
    Niagara Falls, ON
    On my mod, I use no limit sensors/switches. I watch for the canvas sidewalls approaching "taut". Lowering is not an issue. As for "giving out", should not be an issue either. If the winch can handle raising the roof, it should not slip. And of course you use safety supports, right? [;)]
    Cheers.
  12. rawhite1969
    52
    Sep 12, 2009
    Indianapolis IN
    good to know. & yes on the safety supports. My winch is on the tongue and looks to be a fairly simple swap.
    Looks like a good project for the winter! Key now is to pick up an appropriate winch at a great price!
  13. TNBluegrass
    TNBluegrass New Member
    33
    Sep 17, 2009
    Crossville,TN
    anyone know if this conversion is possible on a goshen lift system? I have 93 Skamper
  14. Crazycoleman
    142
    Sep 21, 2008
    Henrietta, Tx
    If your Skamper is anything like mine, it looks like a super simple swap. The hardest part would be just rethreading the cable thru the lift tube and wiring up the power winch.
    ROb
  15. Island Ranger
    Island Ranger New Member
    880
    Aug 14, 2006
    United Kingdom
    Can't help but a great mod you must post how you did it with some pics when its all done.
  16. theseus
    theseus Centerville, OH
    2,896
    437
    Feb 6, 2007
    Centerville, OH
    For those of you considering this project, here is a link to a seller who is selling Carefree of Colorado's winch for $149.
    http://www.powerwinch.com/powerwinch/controller?action=sale
  17. sg1215
    sg1215 my God, my Country, my Family, my Friends, myself
    151
    Jan 13, 2010
    are there any pictures of this mod???
