Advice on fixing my bunk end slide out wheel
Discussion in 'Slide-Outs / Bunkends' started by Popitlikeitshot, Feb 10, 2020.
  1. Popitlikeitshot
    Popitlikeitshot New Member
    Feb 9, 2020
    Toronto, Ontario, Canada
    Below is a picture of my king bunk end slide out wheel on my 2000 palomino yearling. It is tilted to one side and am not too sure how to go about fixing it. Any advice would be great!!
  2. eoleson1
    eoleson1 Well-Known Member
    2,254
    687
    Jul 5, 2011
    Macomb County Michigan
    The one on my Starcraft was held on using screws. If yours is too, maybe one broke?
  3. Popitlikeitshot
    Feb 9, 2020
    Ah thank you! I didn’t manage to get a great look at it this past weekend but we’re going back up to see if we can fix it this weekend so I will bring some extra screws just in case!!! Thank you!!
  4. myride
    myride Well-Known Member
    878
    397
    May 14, 2015
    Edmonton, AB
    My palomino used to do that also....it's a guide wheel NOT used to support anything and looking at it it has spun around as mine had at times....spin it so the wheel is more DOWN than up....and tighten/add a screw.
  5. Popitlikeitshot
    Feb 9, 2020
    It is actually fixed to the camper by one bolt. Not screws. So it is possibly that it has spun around. So that bed is actually very difficult to pull out. Is it because of the wheel or could it be something else? We lifted it and it still took 2 people on the outside and 2 on the inside just to get it out.
  6. bheff
    bheff Well-Known Member
    1,011
    508
    Feb 24, 2011
    NW Arkansas
    Something is wrong. Clean and lube the rails. I can pull my beds out with one hand.
  7. myride
    878
    397
    May 14, 2015
    Edmonton, AB
    You probably need to put some lube in the bed tracks to have them slide better. Tighten the bolt then add a screw to stop it from spinning.
    Popitlikeitshot likes this.
  8. tfischer
    tfischer Well-Known Member
    3,573
    1,074
    May 21, 2014
    Our Palomino has the same setup. That wheel helps guide the bed slide over the lip of the camper edge, if it isn't in place (as ours likes to do also) you will hang up on the support pole brackets, and some other things, and have to curse and force it into place.
  9. myride
    878
    397
    May 14, 2015
    Edmonton, AB
    Hence the reason I put a second screw in after resetting the wheel....prevents it from twisting.
    tfischer likes this.
  10. Popitlikeitshot
    Feb 9, 2020
    tfischer thank you! should the wheel be more up or down? the middle of the bed is catching on the edge of the camper due to the wheel not being properly in place... very annoying to get the bed out. we need 2 people pulling, 1 pushing from the inside and someone underneath pushing the bed up! We will also be lubricating the tracks and everything. We just bought this trailer about 2 weeks ago and have a lot of work to do but can't do much just the two of us because we can't pull that bed out just the two of us haha!!
  11. tfischer
    3,573
    1,074
    May 21, 2014
    It should be perpendicular to the edge of the camper.
  12. Popitlikeitshot
    Feb 9, 2020
    Ok guys! Went up to the trailer today. Fixed the wheel, cleaned and lubricated the tracks and now the bed slides like a dream!! Thanks for the advice! Now onto the next task!
    tfischer and Sjm9911 like this.
