air conditioner cover for aliner
Discussion in 'A-Frame PopUps' started by Ernest Gonzalez, May 25, 2018.
  1. Ernest Gonzalez
    Ernest Gonzalez New Member
    May 25, 2018
    I just replaced the air conditioner with a new one - second time since 2012. But the LG LW5016 replacement is a little longer, and the old cover won't fit. Any ideas for finding a cover?
  2. PointyCamper
    PointyCamper Active Member
    591
    158
    Nov 25, 2015
  3. razcob
    razcob Member
    98
    25
    Jan 4, 2018
    Powhatan, VA
    I ordered two from Aliner and both are too short.
    In the morning, I’ll take a picture of a cheap solution that works.
  4. razcob
    razcob Member
    98
    25
    Jan 4, 2018
    Powhatan, VA
    This temporary, but now permanent fix works great. Didn’t move after a 9 hour interstate drive. Paracord and a wooden rod. If the wooden rod moves backwards, it will stop before the paracord disconnects in the front.
  5. Raycfe
    15,386
    1,569
    I thought I read an article about making the air cond removable on Aliners. If your sticks out by the door as some I have seen thats what I would do. But I am not an Aliner expert. Just was thinking about getting one ....once.
  6. Ernest Gonzalez
    May 25, 2018
    Looks like a clever fix. Thanks
  7. Tukee44
    Tukee44 Member
    282
    Apr 28, 2012
    The OEM cover is a piece of junk. It shrank and rot under the sun. I sewed one myself using Sunbella fabric bought on ebay. Expect it last longer than the trailer.
  8. SusanRife
    SusanRife New Member
    Aug 30, 2018
    Morgan Hill, California
    What did you use to replace the narrow metal rod that slides through the slot above the a/c unit? I was thinking the Sunbrella fabric would work great but my sewing machine won't stitch through that vinyl.
  9. Racheal
    Racheal New Member
    Aug 31, 2018
    Could you [ost how you made it.
  10. Lynn Harland
    Lynn Harland New Member
    Aug 9, 2019
    This is so clever! I had to replace the OEM AC unit when it died and the replacement unit is a different size, so the old AC cover won't work. I will get Sunbrella fabric as suggested and try to use your strategy with the wooden rod. I wish I could see a little more detail on how the cord is attached to the rod (and I would love to see the bottom two corners of the cover. Any chance of a few close-up photos so I can duplicate your genius-ness? : - )
  11. razcob
    razcob Member
    98
    25
    Jan 4, 2018
    Powhatan, VA
    I just use slip knots to tie each cord around the wood. NOTE: I would highly recommend that you put a lacquer or some paint on the rod.
    megcabra likes this.
  12. FLWanderer
    FLWanderer New Member
    Dec 3, 2019
    Great idea on using the wooden rod and sunbrella material. Thank you for sharing.
