Air conditioning condensation leaking into camper
Discussion in 'First Time & New Camper Owners' started by scrooge, Jul 21, 2015.
  1. scrooge
    scrooge New Member
    Jun 26, 2015
    I ran my 2007 fleet wood Yuma AC for about 12 hours with no problem. However, all of a sudden water starts leaking out of the AC unit on to my dining table. What is causing this? This was my first time out with the camper.
  2. Customer
    Customer Well-Known Member
    2,435
    246
    Jun 5, 2014
    Condensation maybe? Pull the cover off and take a look.
  3. scrooge
    scrooge New Member
    Jun 26, 2015
    It is condensation, but why is it leaking through the inside AC unit?
  4. shuang2
    shuang2 Well-Known Member
    1,194
    102
    Apr 20, 2010
    I have same problem...looking for a solution too!
  5. swordfish
    swordfish Well-Known Member
    2,214
    41
    Sep 27, 2010
    It was an overload protection feature that Fleetwood added to 2007 and newer pups. Once you see water on the dinette table it is time to turn off the A.C. to avoid possible electrical fire.
  6. speckhunter80
    4,782
    64
    Jul 26, 2012
    Shell Rock Landing, Hubert NC
    Check to see if the drain is clogged...
  7. scrooge
    scrooge New Member
    Jun 26, 2015
    Where is the drain located?
  8. mckeapc67
    mckeapc67 New Member
    681
    Feb 22, 2011
    I have the same issue. My rooftop unit is a Carrier unit.
    I have found that it is very picky on being level. If the PUP isn't perfectly level, then when the A/C builds up condensation inside, it "splashes" into the vent and eventually runs over into the PUP. I can look up through the filters and see if the water is splashing. If I see it splashing/blowing around, I know the leak is coming and I better check level.
    Hope this helps you.
  9. CyVaquero
    CyVaquero New Member
    Jul 13, 2015
    I had the same problem this past weekend on my inaugural run with our new to us Fleetwood E3. We were camping in 90+ degree weather with above 90% humidity and we started leaking as soon as the A/C started to cool. First searches on the problem gave me the condensation answer but after talking to another PUP owner in the campground who didn't have the problem I did a little more digging.
    Check the long hex mounting bolts on the inside. You should be able to see them without removing the inside cover but you need to remove it to access them. They sandwich the roof unit to the inside mounting plate with the roof and seal in the middle. If they are loose (in my case two had worked themselves all the way out to the inside cover), you don't have a good seal and some/all the drain water on the roof is running back into A/C, tighten them up. This fixed my problem.
    Last suggestion I have is check the seal itself and see if it is worn and needs replaced.
    Also, you probably want your PUP to be just slightly off-level (toward a corner) so that the drainage will run off and not sit up there (the other PUP owner had pointed out that he thought I might be 'too' level).
    Not an expert on this so I hope it helps.
  10. scrooge
    scrooge New Member
    Jun 26, 2015
    I pulled the AC cover and took a look at things. I did not see anything out of place. I guess it's time to take it to the dealer. I don't want to deal with another hot night.
  11. mckeapc67
    681
    Feb 22, 2011
    Did you take the cover off while it was running and leaking?
    If its like mine, after it runs for a bit in hot humidity, I can see the water blowing around in the unit if it's not properly leveled.
    [2C]
  12. nineoaks2004
    8,214
    3,677
    Dukes, Fl
    Sounds like the gasket , remove the inside cover and look for the four bolts that hold the unit on the roof, see it they have loosened up, if so tighten them. Also look at the gasket while cover is off and see if it has a badly crimped down look, they have a problem of compressing and getting hard with old age. It is probably the bolts are loose, they have a habit of loosening up as the gasket compresses.
  13. Lolo Tee
    Lolo Tee New Member
    Dec 30, 2017
    San Diego, CA
    This is my inaugural Pup Portal post, wanted to thank you all for all the tips, I fixed the A/C leak! Now I’m replacing two compartment doors, mounting my propane tank, and replacing all my bulbs w LEDs.. wahoooo!
  14. CCundiff
    CCundiff Member
    92
    Feb 19, 2010
    +1 on the gasket. Had same issue. The bolts do come loose sometimes. Just don’t over tighten
    Lolo Tee likes this.
