Air mattress pumps
Discussion in 'Campsite Electronics' started by Brad Jackson, Dec 9, 2018.
  1. Brad Jackson
    Brad Jackson Member
    66
    28
    Aug 25, 2018
    wooster,ohio
    I have a air mattress pump, battery kind....instead of wasting a lot of batteries is there a pump you can get battery and electric? Since my pump takes 6 batteries
  2. PopUpSteve
    PopUpSteve Administrator
    19,196
    1,951
    Dec 22, 2002
    Malvern, PA
    Brad Jackson likes this.
  3. gladecreekwy
    920
    1,178
    Sep 25, 2016
    Jackson Hole
    Do you carry a portable compressor? If not it’s a good idea for tires and can inflate air mattress and pool toys as well.
  4. Matt Benoit
    Matt Benoit Well-Known Member
    544
    333
    Jul 30, 2017
    Warren, MI
    I've had 3 different types...
    120v works great. Very fast. Definitely the strongest of the 3.
    Battery. Requires 6 C batteries. Ultra portable. Terribly slow and under powered.
    12v (cigarette lighter). Best of both worlds. Portable and just as powerful as the 120v.
    I could deal with the slow speed of the battery powered pump. The real problem is that I couldn't get it to build enough pressure inside the mattresses. I like a firm bed, and the battery powered pump didn't cut it.
    Anthony Hitchings and Katskamper like this.
  5. nineoaks2004
    7,871
    3,477
    Dukes, Fl
    I have a 12 V and also 110V pump, I believe I bought the electric pump at Wally World
    Katskamper likes this.
  6. Katskamper
    Katskamper Active Member
    778
    224
    Nov 21, 2015
    Fort Worth, TX
    my battery pump is rechargeable
  7. Sjm9911
    6,458
    3,825
    I have a battery pump, it works pretty well atually.
  8. jmkay1
    5,505
    2,286
    I have a 12v pump that's works great. I didn't even know they had a battery pump, but since I have a 12v outlet in the back of my SUV it is usually isn't that much of a problem. Except if the air mattress lost its air in the middle of the night. It's way too noisy to use it in the middle of the night and a pain to have to take the mattress out of the tent. For some reason I always landed on the ground at least once or twice a trip.
  9. Brad Jackson
    Brad Jackson Member
    66
    28
    Aug 25, 2018
    wooster,ohio
  10. Kampus
    Kampus Active Member
    206
    200
    Jun 16, 2017
    Slate Belt, Pa
    This is the one I have, works great. I carry a booster pack/lot jumper just in case. It has a 12v outlet so I can pump up wherever I need.
    You can also suck with it. Makes deflating quick and nice and tight for folding back up.
  11. Kampus
    206
    200
    Jun 16, 2017
    Slate Belt, Pa
    Any car with a 12v outlet...or you could cut the 12v plug off and add alligator clips to attached directly to a battery.
  12. BillyMc
    BillyMc Well-Known Member
    1,420
    745
    Mar 25, 2018
    I use a 150 watt inverter with the 100 volt pump that came with the mattress.
  13. dbhost
    dbhost Well-Known Member
    814
    323
    Sep 19, 2018
    League City, Texas USA.
    My pump takes 4 D cell batteries. There are also manual pumps that are actually quite efficient and inflating air beds, inflatable toys etc... Not so great at higher pressure applications though.
