Alarm in Pup
Discussion in 'General Camping Discussion Forum' started by Whopper14, May 30, 2018.
  1. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    My pup is closed up and wife said there was an alarm going off. She thought it was the neighbor doing something, stopped after an hour or so. Anyone know what it could have been? It is about 90 today, it is sitting in full sun. Planning to check battery, taking it out this weekend. Thoughts...
  2. JPBar
    JPBar Well-Known Member
    1,873
    583
    Sep 22, 2016
    Texas
    If you battery is hooked up it is probably the CO/LP detector will go off due to low battery
  3. jmkay1
    5,797
    2,608
    It could be a battery low alarm if you didn't unhook you battery before storage. Campers have a paracidic charge that could discharge a battery if it didn't get disconnected or camper plugged in.
  4. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    We have used PUP a couple of weeks ago and battery has been charged for season. I will check battery and charge as well.
  5. tombiasi
    6,010
    1,528
    Before you can get a real answer you need to open it and see what alarm is going off.
  6. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    Battery was reading about 6v, don't know why. Battery is what came in PUP and it's less than a year old. Can't think of anything left on to drain battery. Battery is now on charger.
  7. jmkay1
    5,797
    2,608
    If you have a carbon dioxide alarm there is always a little power draw that comes off of that and in a two week time, could discharge your battery. After every trip, it is best to disconnect the negative wire to prevent the discharge.
  8. Whopper14
    Whopper14 Member
    42
    Jun 20, 2017
    Holland Mi
    I will start doing that, thanks.
  9. CO Hiker
    CO Hiker Active Member
    282
    68
    Dec 6, 2015
    Colorado
    Smoke alarm battery low?
  10. tfischer
    tfischer Well-Known Member
    4,039
    1,520
    May 21, 2014
    We always just remove the fuse from the battery when in storage (we store off-site and can't keep it charging)
